Home > Maintenance & Mods (L322) > power steering fluid
marshy
Australia 2002 Range Rover HSE 4.4 V8 Buckingham Blue
Hi all I am wanting to know if there is a alternative to theTexaco Cold Climate PAS Fluid 14315
Land rover wants $77+ dollars for a ltr and all I want to do is top it up. Censored
thanks
Post #270688 14th Jul 2014 5:13am
netsonic Steve
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
As long as your not planning a trip to the north pole ATF Dexron IID or III will be fine...........£5 a litre here in the UK
Post #270828 14th Jul 2014 6:51pm
marshy
Thanks
Post #270890 14th Jul 2014 9:13pm
frikkadel
South Africa
I am in south africa, so can i use the normal dexron ATF or is there a higher grade fluid?
Post #396941 21st Jul 2016 7:43am
Andy K
United Kingdom 2005 Range Rover HSE Supercharged Rimini Red
See what your owners manual says in the back, as you are in a hot climate
Post #396959 21st Jul 2016 9:23am
p38arover
Australia
Re: power steering fluid
thanks
I needed some for my L322 steering. Hunting around, Penrite have a 14315 equivalent PAS FLUID - (Power Assisted Steering Fluid) but it's $28/litre at SuperCheap.
SuperCrap have 20% off all floor stock this Saturday 23rd. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #396968 21st Jul 2016 11:10am
Alfasprint88
New Zealand 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Supercheap has 25% off over the ditch. Shall I get you some and post it to you? Rolling with laughter
Post #397095 22nd Jul 2016 8:18am
