Home > Technical (L322) > Eml
alib123
Eml
Good morning all, ive had a light come up on the dash, looks as though its camshaft issue of some sort. I pulled the sensors out yesterday and one looks cracked and messed up, see pics. Im assuming this would explain my low idle revs and stalling issues!
I would like to ask if anyone knows where I can get some new ones as i spent most of last night looking in the usual places to no avail, apart from some used examples on ebay.
Also is there any recommendations of a cheap fault code reader that is able to switch the light off after repair? I dont want/need to change perameters etc so just something capable of resetting would be sufficient, unless its not that simple?
Please accept my apologies for all the questions but ive taken the car to several garages and its now a case of if u want something doing properly do it yourself. Im capable of doing it but just need some guidance from you guys that are in the know!
Thanks again
Post #270561 13th Jul 2014 11:08am
alib123
pics are in gallery, sorry
Post #270586 13th Jul 2014 1:07pm
Thumbs Up ... - .- -.
Post #270588 13th Jul 2014 1:09pm
alib123
Thanks!, they look terrible dont they?!
Post #270590 13th Jul 2014 1:20pm
alib123
Bump, any ideas guys, im struggling
Post #270640 13th Jul 2014 6:54pm
Can't help with the sensor problem. Suggest you contact Dan at Duckworths LR on the forum for this specific part. You can identify part number by using the online microcat at lrparts.ru.
But if you have an android smartphone you can buy an ELM327 bluetooth OBDII adapter of ebay for @ £5 then download the Torque App (limited functionality is free but the pro version well worth the additional £5 too)
Should be able to clear standard OBD faults with this, works on my other cars. .
Post #270675 13th Jul 2014 11:26pm
johnboyairey
I have a diagnostic tool I could reset and give you a check over I'm in Chessington area if you come that way but I've a couple of holidays looming maybe put out a 'anyone near with a diag tool' request. Pm me if you are struggling I have Same model car and I might have a spare sensor you can borrow by post too... I think I have the pair I will look tomorrow remind me with a PM
Post #270681 14th Jul 2014 12:32am
Winchester101
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
I also have something to help an I live in essex like you I also had the camshaft problem like you 1994 softail full stars n stripes custom harley davidson
Post #270689 14th Jul 2014 6:56am
alib123
Thanks all for your kind offers and advice. Il see what I can sort out parts wise then may have to take one of you up on the offer of help.
Winchester101, Where abouts in Essex are you?
Just to put my mind at rest, the sensors shouldn't look like that should they?
Thanks again
Post #270822 14th Jul 2014 7:33pm
here are a couple of pics [from a google search] that hopefully you can compare,
Post #270826 14th Jul 2014 7:46pm
Winchester101
Stan not sure they are quite right mine diddnt plug in at that end they had a cable on them and benfleet alib123 1994 softail full stars n stripes custom harley davidson
Post #270827 14th Jul 2014 7:50pm
maybe not exact but this should give an ideas on the condition they should be.. ... - .- -.
Post #270830 14th Jul 2014 7:53pm
alib123
Thanks, i googled yesterday and there were loads clean like this which is why alarm bells started ringing!! Benfleet, wow, im only in wickford so not far at all.
Post #270835 14th Jul 2014 8:00pm
Winchester101
I'm happy with that Stan Thumbs Up Bow down wickford just down the street 1994 softail full stars n stripes custom harley davidson
Post #270838 14th Jul 2014 8:18pm
johnboyairey
they are in the oil splash area, ie next to the timing chain path. and may have baked 'grot' on them. they have magnetic properties, they sense a gap in a rotating metal wheel on front of camshaft(s) and relay it electrically, to the brain. if it gets a break of signal it would lose synch, and the brain would register a trouble code. car could stall. this can be read and point you (hopefully) to the offending sensor. they could test good when cold and go bad for just a few milliseconds, and then good again. so don't think it will 'look bad' to the eye. though it could, and it could also be bad when cold and good when hot also. a diagnostic tool will tell you the code, and point you well. by taking it off and putting it back on, you might have also cleared the fault. -hopefully for it never to return. maybe just a bad connector plug..... take only one off at a time though.
I think actually I don't have the (mentioned earlier) cam sensors to hand, , I have a pair of knock sensors....
Post #270908 15th Jul 2014 12:20am
