Home > Maintenance & Mods (L322) > L322 4.4 Transmission temperature problem?
Mistercorn
United Kingdom 2010 Range Rover Autobiography 4.4 V8 Java Black
I was towing a couple of tons the other day and my car went in to the mode where it hangs on to gears longer. I plugged in my IID tool and it showed a transmission temperature of 140 degrees. When I dropped off the trailer and waited a while then drove home without anything on the back the temperature rose again up to close to 140.
This morning I drove 15 miles to work with no load on the car. At the start of the journey the temperature showed 34 degrees (ambient about 14), when I got here the IID tool showed 117 degrees, an IR temperature check on the sump showed 93 degrees.
As such it sounds like a dodgy sensor, but has anybody ever seen one fail like this? I would expect it either to work or not work. Any suggestions on the best course of action?
MC
Post #270235 11th Jul 2014 6:21am
Bagus
United Kingdom 2016 Range Rover Autobiography 5.0 SC V8 Loire Blue
I had the sensor fail on me. Drove 5 miles and got the "transmission overheat" message on dash. But later that day I drove
80 miles with no error message. Seemed worse if I was driving through traffic eg constant gear changes.
Anyway I had the sensor replaced (means new wiring harness for c£120 from land rover although I think you can find them for c£65) and new oil etc. all up it came to £500 but that fixed the problem.
Post #270264 11th Jul 2014 8:50am
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Had a similar problems a couple of years ago on a drive back to Wiltshire from Cornwall, got 6 miles from home and got the trans overheat gearbox mode. We ended up replacing the radiator and trans oil cooler.
On the early 4.4's the bottom 6 rows of the radiator collapsed internally thus reducing the coolant flow to the trans oil cooler.
May just be a sensor but I'd get the radiator / trans oil cooler checked as well. There is a flow test that can be done on the radiator.
Post #270265 11th Jul 2014 9:11am
Mistercorn
That was my first suspicion as well, particularly as sensors tend to either work or fail. When it reported 34 degrees when I started the car up this morning having sat on the road all night that looks like a sensor issue.
MC
Post #270278 11th Jul 2014 10:29am
Bagus
I think the issue with the sensors is they rise but dont reset hence why it records a much higher reading than the actual temperature. Trick the system into thinking its actually overheating. Your IR reading would suggest sensor issues.
Post #270279 11th Jul 2014 10:36am
