![]() | Home > General (L405) > Is this device standard if you have a full-sized spare? |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
I saw this in the Owners' Manual:
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1099 ![]() ![]() |
It is OK your Omnimpetent, the man from LR assist will know how to do it. |
But will he find me in the far corner of the grouse moor? |
I was rather thinking I'd get my loader to change it for me. |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3756 ![]() ![]() |
Ah yes, you mean you have a man servant |
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 ![]() ![]() ![]() |
I haven't got it in mine and that wheel is bl**dy heavy!
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Much like a later model 322 then (since they removed the straps) |
On the 4.2 I have had two flats in Nigeria and on the first I didn't realize the tailgate was to be used as part of the removal procedure. Once you know that trick it becomes easy peasy (I used it a few times after that and it makes life soooooo much easier).
You won't have one Eugene... jLR delegated them in late 2005!!! Dan will sell you one for around £30 |
Screw that |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Eugene...what's the tailgate procedure then?...do tell
Plug the bracket into the "lock" opening of the lower tailgate and lower the lower tailgate. The straps tighten and the tyre pops up |
Cheers...looks like I'll be contacting Dan too |
Mine has it.
