![]() | Home > Technical (L322) > Fancy a Full Fat with a 2.0 4 cylinder diesel engine? |
This is the new JLR Ingenium 2.0 4 cylinder engine that will be in production from next year.
It'll come as a petrol and diesel both with turbocharging. Rumours of diesels with 250bhp and petrols with 400bhp ![]() It's meant to be very efficient as well as powerful. Low friction roller bearings for the camshaft. ![]() No idea why the cam drive is at the back. As well as not taking the torque strain off the crankshaft it seems difficult to access. I'm sure there's a reason. ![]() There's no suggestion it'll be installed on the L405 yet, but given it's output is compareable with the 3.0 6 cylinder diesel - how would you feel about it if it was? Personally, I just don't like the 4 cylinder diesel drone. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Java Jungle Member Since: 22 Mar 2010 Location: Monte-Carlo Posts: 420 ![]() ![]() ![]() |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2616 ![]() ![]() |
Surely a definite for the RR Sport. Discovery Sport apparently will be launched without it as the engine plant won't be up and running in time (according to Autocar, so pinch of salt). Quite interesting engine - offset crank etc. |
andy180 Member Since: 26 Aug 2010 Location: scotland Posts: 509 ![]() ![]() ![]() |
I can see it in a low spec SSRR.... but no chance in the full fat
Times have changed, Car magazine quoted someone from JLR saying it hadn't been ruled out. There's been a 2.1 litre, 4-cylinder diesel S Class for a few years now. |
I agree times change but the 2.1 litre is only available in the S Class as a hybrid not as an independent unit
Yes, hybrid-only now, but it wasn't in the last one. |
They reckon it'll have the output of the current 3.0 diesel, and it'll be lighter, so all this 'won't work in a big heavy car' is a bit meaningless.
I was in a friends 320d recently and was disappointed with the noise. And it was worse even then my ancient TD6. I think that's the biggest issue, but will be interested to see what it's really like. |
Well boys and girls you had better get used to it because over the next few years, small capacity -high output engines will replace ALL large capacity engines all be it with highbred as well for more performance . The world is changing and we might as well enjoy are large capacity characterful engines whilst we can . |
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 ![]() ![]() ![]() |
Axle is right, times are changing.
To be brutally frank I was never a big lover of the 2.2d as fitted to Freelander and the poverty spec Jag XF but only because of refinement issues. It was like driving a tractor.
If they'd stick an electric motor inbetween or even better let it drive a generator and use hub motors, then something very interesting can happen. Since the combustion engine is now disconnected from the drive train, it can run at optimum speed/performance for the generator to drive the hub motors and charge the battery pack.
