![]() | Home > Maintenance & Mods (L322) > Condensation on inside of rear lens |
Vigneron Member Since: 13 Dec 2008 Location: Seattle Posts: 16 ![]() ![]() ![]() |
The rear light assembly is vented. That is how the condensation got there in the first place. Those of us living in wet climates have it worse.
kin Member Since: 20 Nov 2008 Location: rainy city Posts: 348 ![]() ![]() ![]() |
Thanks |
mine was covered under warranty. 08 FFRR
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Those without warranty are stuffed, like me.
Blue Yonder Member Since: 07 Apr 2009 Location: Blackpool Posts: 13 ![]() ![]() ![]() |
I had this take the lens out dry out perfectly infront of a heater overnight make sure bone dry inside and run a thin bead of silicon around where the lens joins the lamp body. Let dry, refit done. |
Mine was replaced under warranty.. |
And when you remove the light you'll no doubt snap the pathetic plastic clip that secures it, and your dealer won;t sell you a new one on it's own! ![]() 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top *Gone:L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
it is an annoying fault when you think how many other cars at a snip of the cost of a rangie dont have this problem. |
dantheman Member Since: 02 Feb 2009 Location: North: Lancs Posts: 477 ![]() ![]() |
Agreed - seems to be a common problem (?)... Will they not admit fault and rectify this? You should not have to take a hairdrier to them - or remove and reseal with silicon sealant...
Just look on this as one of the unique idiosyncracies of Range Rover ownership Discovery 4 HSE
