Home > Technical (L322) > 2007 L322 gear change problem
1959terry
United Kingdom 2015 Range Rover Vogue SE SDV8 Santorini Black
Hi, just got a 3.6 TDV8 and the gear change between 1st and 2nd gear is quite harsh. All other gears are perfect. It has 52,000 miles on the clock and has full service history. Has anyone got any suggestions?
Terry
Post #269264 5th Jul 2014 3:00pm
Have a search as there is good info on it. There is a gearbox software update which can be done which helps, so will a gearbox oil and filter change.
It is a pretty common complaint. Mine was much better after the fluids swap. But to be honest it seems to be a characteristic of the box. There is nothing that can't be fixed with a hammer😜😜
Post #269383 6th Jul 2014 4:59pm
ebajema
It is not the common EDS4 fault but could be. I suggest to get the fault codes read and see if there is anything like the ones mentioned in below post.
http://www.fullfatrr.com/forum/topic17348....ing+rrphil MY 2010 5.0 SC Galway green and sand interior!!
Post #269439 6th Jul 2014 10:35pm
n1cktdv8
As I am heading to france and doing around 1500 miles with tintent I am having the box freshly oiled....also been recommended the Lucas gearbox additive ? Anyone heard its any good....
Garage tell me the box is a little harsh 1-2 in fairness, but they too say the new fluid and software update usually sort it Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #269442 6th Jul 2014 10:41pm
ebajema
Suggest to just stay with the lifeguard 6 fluid and no additives whatsoever. New fluid and filter always a good idea when the box gets to its mileage limit on fluid change 100k miles. MY 2010 5.0 SC Galway green and sand interior!!
Post #269443 6th Jul 2014 11:43pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Driving style can affect changes too. I drive my sc like a mentalist, but when the missus drives it you can feel the gearbox clonk when it's trying to be civilised.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #269473 7th Jul 2014 9:58am
