![]() | Home > Maintenance & Mods (L322) > B-Pillar trim |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35484 ![]() ![]() |
this is from the WM, hope it helps,
hongkongphooey Member Since: 26 Aug 2010 Location: Douglas. Posts: 227 ![]() ![]() |
Thanks for that Stan, I've had the complete pillar cover off and seen how it's supposed to clip back on, but it has to go back on in one piece and you can't see if the pins are lined up properly, as they're on sliding mounts.
idrawcad Member Since: 13 Jun 2014 Location: Sunny Bournemouth Posts: 144 ![]() ![]() ![]() |
Gripfill My Motto: If you are going to have one, have a BIG one! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
It's easier if you take both door seals off, just from the edge of the pillar trim, then refit it, then refit the door seals... Pete
Had another look and the best way would be to get rid if the drivers seat for access at the lower forward edge, However..... That sir is a very good idea and might just be the answer to a quick way around it! |
