Home > Maintenance & Mods (L322) > B-Pillar trim
hongkongphooey
Isle Of Man
B-Pillar trim
Wow, Land Rover, what a piece of design!
I decided to pop the cover off the b-pillar to clean out the fluff and maybe spray some silicone on the belt and runners etc to speed up the recoil of the drivers seat belt.
What a monumental PITA to get that back on! 2 hrs of pee-ing about and I've still only got 3 of the 4 panel clips located along with the seat belt height adjuster. Now the plastic pins have bent a bit and are moveable so lining up needs some kind of zen like knowledge and possibly x-Ray vision! Smile
Any suggestions on getting it all back together? I might try a new set of pins, failing that, I might just plump for 30mins labour at the stealers to sort the bloody thing out.
And...... Breathe Smile Present* 2006 Santorini SC Vogue SE.
Gone* 2006 4.4 AJV8 Zermatt Vogue.
Gone* 2004 TD6 Bonatti Vogue.
Post #268485 1st Jul 2014 11:37pm
this is from the WM, hope it helps,
Post #268526 2nd Jul 2014 9:10am
hongkongphooey
Isle Of Man
Thanks for that Stan, I've had the complete pillar cover off and seen how it's supposed to clip back on, but it has to go back on in one piece and you can't see if the pins are lined up properly, as they're on sliding mounts.
Never mind, I've ordered some new clips/pins as the old ones are a tad bent now :p Present* 2006 Santorini SC Vogue SE.
Post #268969 3rd Jul 2014 9:55pm
idrawcad
United Kingdom 2003 Range Rover HSE 4.4 V8 Alveston Red
Gripfill My Motto: If you are going to have one, have a BIG one!
Post #268988 3rd Jul 2014 10:38pm
It's easier if you take both door seals off, just from the edge of the pillar trim, then refit it, then refit the door seals... Pete
Post #269083 4th Jul 2014 3:21pm
hongkongphooey
Isle Of Man
Had another look and the best way would be to get rid if the drivers seat for access at the lower forward edge, However..... That sir is a very good idea and might just be the answer to a quick way around it! Thumbs Up
Cheers for the idea. Present* 2006 Santorini SC Vogue SE.
Post #269085 4th Jul 2014 3:30pm
