![]() | Home > Maintenance & Mods (L322) > Engine replacement. |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 ![]() ![]() ![]() |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
Check the crankcase breather. Seems to get missed when servicing and blocks up and causes all sorts of issues.
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 ![]() ![]() ![]() |
the bmw part no for the crankcase filter is 11 12 7 799 367 |
This thread. I didn't know about the upgrade. I will do it to mine when the crankcase breather is due for replacement. Thanks. ![]() @ Vaz - good luck with the project. Looking forward to the updates. ![]() |
I think everyone with a td6 should upgrade the crankcase breather. Did mine within a week of buying it. Also if you fit an aftermarket air filter that you don't change for a while, the top doesn't have to come off the engine during a service, and my garage charge me less due to the reduced labour and part needs.......
Yes, it sounds a very good upgrade. Mine was changed 2 months ago so I won't do it right away.
paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502 ![]() ![]() ![]() |
I did mine after reading about it on here. |
Well made a start around 3pm today and started stripping the front end down. Got the bumper off and other stuff then realised no pictures. Took this one about 1-1/2 hours into the job.
We've been playing this game recently. The car on the right - is it a Rolls Royce Silver Shadow? |
One point to Mr Verbose |
Got the engine out, quite a heavy lump I would guess at around 250kg.
Yes! Do the converter if it is just hanging there! Def!! And a fluid drain (flush is not really necessary as that is mainly for the converter). And you might think about swapping in a valbe body modified with Sonnax bits.
Thanks for that, will defiantly do the TC had a reasonable quote from JPat, collection, remanufactured and return carriage.
JPat have something in their catalog, IIRC. Might want to ask them... |
Do a search for sonnax on here as I know I posted quotes I got at some point.
