![]() | Home > Maintenance & Mods (L322) > Engine replacement. |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 ![]() ![]() ![]() |
Received the transmission oil today.
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 ![]() ![]() |
oil in 2004 td6 should be red (from factory) |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
RRphil to the rescue, scroll down the posting to the photo of the transmission oils:
Craig. Thanks for the tip regarding the bonnet. I already knew about that, the same setup on the P38.
Carried on with the motor yesterday (can't believe it is nearly two months since I removed the old engine), got the motor on the lift Thursday afternoon.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
had a similar issue on my old p38, re immobiliser, did you lock the car with the ecu disconnected?. if so, it looses is synchronisation. (on p38) I needed to buy a 'blackbox' to plug in and it re-synched itself.
Well got the engine running today, after a couple of days chasing none existent faults. I think when something doesn't do what you think it should, you are tempted to have a probe about and this then gets too deep.
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
Great read. Fair play to you. Much respect! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
Top job mate, bet that was a relief when it started....
Enjoyed reading that very interesting and its Giverney Green!
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 ![]() ![]() ![]() |
My second favourite colour |
Maybe give it a 2012 facelift....
Thanks for all the comments much appreciated.
