Home > Wheels & Tyres > Nexen Blog |
markdotreed Member Since: 05 Sep 2011 Location: Ropley Posts: 741 |
So... My two new Nexens arrived in better post, 48 hours after ordering them. Just under £180 to your door which isn't to be sniffed at.
2nd Jul 2014 9:57pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Present :2008 TDV8 HSE
2nd Jul 2014 10:01pm |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 |
Just ordered 4 for mine see how they go but £260 delivered Mine was a blue one! |
3rd Jul 2014 9:46am |
Any feedback on these yet as all very quiet Present :2008 TDV8 HSE
9th Aug 2014 7:51pm |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 |
I binned mine off and went back to real tyres
9th Aug 2014 9:07pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
I found nexens a good budget tyre. The road holding was good, they stopped the car aquaplaning, they were quiet on the road, generally good all round.
9th Aug 2014 9:30pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3747 |
Nexens are ok, and at under - £100 a tyre very good value - they do the job ok and nothing more - but you cannot compare them to a better quality tyre. You notice the difference when the car is driven harder - especially on bends - the soft tyre walls are the limiting factor. I took mine off after 5k miles and replaced them with General AT's - 13k miles and still on 10mm tread depth with a digital scale 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
10th Aug 2014 5:28am |
What size are you running on the ATs? Present :2008 TDV8 HSE
10th Aug 2014 9:48am |
Agree with Welshdragon,
10th Aug 2014 9:49am |
@ Googsy 275 45 20 same dia as std 255 50 20 . The only negative is a slight hum from the tyres but the off road ability and snow capability is far better than the std road tyres / scorpians 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
10th Aug 2014 10:06am |
How is ride for comfort? Just worried about the 45 profile Present :2008 TDV8 HSE
10th Aug 2014 10:34am |
The tyre wall depth is the same with the General AT as oem - the 45 profile is a percentage of the width - if you went to the RRS profile of 275 40 20 them yes there is a difference.
10th Aug 2014 10:42am |
Last question... what psi are you running same as standard 255 50 20 ? Present :2008 TDV8 HSE
10th Aug 2014 11:03am |
