![]() | Home > LPG > LPG...BMW vs Jag |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
That's exactly what i'm running. Superb combination. ![]() |
Ningr Member Since: 20 Jun 2014 Location: Towcester Posts: 63 ![]() ![]() ![]() |
I have the BMW 4.4 LPG with Prinz system.
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
More or less, there are no additives in LPG AFAIK (apart from the 'perfume' that gives it its smell), whereas petrol has many additives, and the 'premium' brands have much better additive packages than the supermarket / cheapo brands.
Trossachsturbo Member Since: 29 Jan 2014 Location: Central Posts: 24 ![]() ![]() ![]() |
Now now |
No offence meant |
None taken, hope you enjoyed your visit. BP station next to Clydeside expressway 68.9p, but agree elsewhere can be pricey |
Thanks for prompt replies, brilliant info as usual on this forum.
gpzjamie Member Since: 11 Aug 2013 Location: newcastle upon tyne Posts: 14 ![]() ![]() ![]() |
would be interesting to see how the lpg cars have worked out since this post, i run my 06 4.2 sc on gas, had no problems in 30k miles, no valve lube. time will tell.Jamie jamie |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
For the record, my 02 BMW engined v8, with a prinz system that was pro fitted at 60k, by previous owner...is now on 165k, and running perfect. -I don't get any error codes, relative to engine running etc. I regularly use shell LPG as its nearest. But I use any station brand, when convenient.
I'm just back from belgium, lpg is 31c a litre, its 55p in my local co-op, what a rip off. jamie |
Still running as normal without any problems. ![]() ![]() |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
morrisons kilmarnock 47.9 pence asda govan 49.9 pence local garage was charging 79.9 pence had to stop using as no one was buying |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2290 ![]() ![]() ![]() |
Had Prinz in a 2002 BMW engined 4.4 and now BRG in my 07 jag engined 4.4. both did great, 82K miles in the 2002 and now 83K in my 07. The latest with valve lube. The system is Serviced every year or 10K miles. Love it and it goes well with my concious, driving a clean V8. When it is very hot (as at the moment and on high altitude I do switch to petrol. A habbit I took in when I drove LPG in the 80ies in Holland, when I did 100K a year. Then they told us that driving petrol when it's hot would grease the valves. Obviously with the valve lube it doesn't seem logical to do it nowadays, but I have the illusion that my car sound smoother in the mountains on petrol. Both cars were converted to LPG after approx 6000 mls from new. Had 1 RR sport and 4 FF now and the LPG cars did not cost me more or gave me more issues. |
csufy Member Since: 17 Feb 2017 Location: Budapest Posts: 12 ![]() ![]() ![]() |
Anyone with experience using CNG? |
