![]() | Home > Maintenance & Mods (L322) > Tow Bar |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 612 ![]() ![]() ![]() |
It's really not that difficult to fit one yourself if you go for the genuine items (got mine from PF Jones), I did. The only difficulty I had was that the bolts that held on the exhaust were seized. Managed to shear one and get the other off by removing the rubber bung, once they were out of the way I cut / drilled them out and replaced with bolts.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8702 ![]() ![]() ![]() |
^what he said, pf jones is your friend if you want to do it yourself, or any tow bar centre should be able to handle it.
Got genuine electrics on mine and only thing I did when installing was to disconnect the battery in the proper manner. |
Yes they do work, but there is an option to enable tow bar in the config files, so the question is what does that actually do?
Or in my case not. First time went to tow a trailer (another Land Rover) got both trail lights and one indicator on?! Turns out I'd put the white socket in the black holder and vice versa so inadvertently plugged it into the caravan socket. Thankfully a quick fix. Maybe next time I pop into the garage I'll ask if they know what enabling the option does. |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
I think it is only the later (post 2010) vehicles which need coding. Mines a 2006, and when I recently fitted a towbar and 13 pin kit for towing our tin tent, without having to have anything coded the car knows when the tin tent is on the back, and the engine and gearbox mapping is altered (clever ba |
160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 455 ![]() ![]() ![]() |
So can anyone tell me what changes are made on a post 2010 car then please?
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2604 ![]() ![]() |
Not sure how this would be implemented - big difference between a bike rack and a tri-axle Ifor Williams with three tonnes of cow in it. Certainly never noticed any difference other than what you'd expect with the load. |
jarv Member Since: 12 Jun 2013 Location: London Posts: 30 ![]() ![]() |
My Westfalia detachable and 13 pin electrics were supplied and fitted a couple of months back by P F Jones, and I live in London. They obviously have a relationship with a mobile fitter down here. Top job and good value. |
Different wiring loom, the towing socket wires are a lot shorter and there's no white box controller to fit. The coding seems to ensure that when towing the rear park sensors and rear fog lights on the car are disabled. |
Muttley Member Since: 21 Apr 2013 Location: Heathrow Posts: 536 ![]() ![]() ![]() |
Many thanks for the help Guys |
SO3isme Member Since: 18 May 2014 Location: Woking Posts: 110 ![]() ![]() ![]() |
Hi, I am missing the swan neck on mine at the moment. can you say exactly what 'fits into the hole under the floor on the right-hand side of the boot so out of the way.' means please? Is that in with the spare wheel?
Thanks! I didn't know about that, and my car is away having the A/C condenser replaced. |
