Home > Technical (L322) > resevoir pressure static when reservoir is inactive |
darrenmax Member Since: 20 Apr 2010 Location: antwerp Posts: 420 |
got the dreaded suspension inactive message today so took the car to the local diagnostics center and they came up with this message,"resevoir pressure static when reservoir is inactive", what does it mean exactly and whats the cure, they tried to reset it but it didn't want to know, now it just stays at ride height 2002 td6 vogue, 06 supercharged facelift
28th Aug 2010 5:10pm |
had a look in the boot at the compressor housing but it seems to be sealed, i wanted to open it and see if i could use my hammer on anything, do i just force it open ?? 2002 td6 vogue, 06 supercharged facelift
29th Aug 2010 2:08pm |
The pressure sensor in the reservoir could have failed. It could also be a worn pump.
29th Aug 2010 2:42pm |
