Home > Technical (L322) > resevoir pressure static when reservoir is inactive
darrenmax
Belgium 2003 Range Rover Vogue Td6 Giverny Green
got the dreaded suspension inactive message today so took the car to the local diagnostics center and they came up with this message,"resevoir pressure static when reservoir is inactive", what does it mean exactly and whats the cure, they tried to reset it but it didn't want to know, now it just stays at ride height Sad 2002 td6 vogue, 06 supercharged facelift
Post #26670 28th Aug 2010 5:10pm
darrenmax
had a look in the boot at the compressor housing but it seems to be sealed, i wanted to open it and see if i could use my hammer on anything, do i just force it open ?? 2002 td6 vogue, 06 supercharged facelift
Post #26716 29th Aug 2010 2:08pm
dan_uk_1984
The pressure sensor in the reservoir could have failed. It could also be a worn pump.
What the message means is:
Whilst the pump is running, the pressure hasn't increased in the reservoir. OR corners go up, using reservoir air, yet the pressure doesnt drop as expected.
Post #26719 29th Aug 2010 2:42pm
