Home > Other Site Sponsors > New firmware & app release, V3.0, for the IIDTool...
Page 1 of 7 1234567>
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Hello Everyone
First, we would like to thank all our customers, beta testers and the community for your continuous support. Many new additions were the results of your feedback and suggestions. We could not be where we are without you!
As many of you already know by now, a new App, version 2.9, for Apple devices was released over the week end. We’ve also released a new special firmware available for beta testers only at the current time. I will do a second post shortly showing each point in detail but here’s a resume of the new additions when using both the new App and firmware or using the new App only with an older firmware.
Top Bar (new and old firmwares): A new bar was added which shows the current connection and ignition status as well as battery voltage.
Faults function (new and old firmwares): Advanced Read
-Status bit flags default selection can be saved for future use
-Status bit flags are visible as icons on top of fault descriptors
-Status bits can be included in the exported emails
Height Adjust (new firmware only): A new and more intuitive screen to adjust your suspension height with default and saved settings. Contrary to our previous method, height changes are relative to the default height and not the current standard height.
0 -> 25: current height, 0 mm, or default in this example is shown on the left while the selected height setting (My offroad height in this example) is shown right, + 25 mm
20 -> -10: current height, +20 mm relative to the normal height (0 mm), shown on the left while the selected height setting (Motorway in this example) is shown right, -10 mm relative to the normal height (0 mm).
Height Control (new firmware only): This function allows you to remotely control your current height (Access, Normal, Offroad) and lower both axles to the bumpstops.
Suspension Calibration (new firmware only):
-New manual calibration layout
-New guided calibration function. This unique method eliminates the need for calculations, even ground and requires only one iteration. The whole process takes 5 minutes.
Guided calibration instructions:
• The first corner to be calibrated is the front left corner (1).
• Place your measuring tape as instructed and use the up and down arrows (2) to reach the required height (3).
• Once completed, click on Send (4). The next corner to be calibrated will now be high-lighted.
• Repeat the previous steps for all corners.
New Suspension Test Valve function layout (new firmware only)
Live values:
-All live values (PIDs) are now available for all supported vehicles (L322: except for older BMW type ECUs, new firmware only)
-Trigger function which allows custom audible or vibration alarm and automatic start/stop logging of live values. (new and old firmwares)
Trigger example:
• The live value increases and passes the Start target of 20 % (first red dotted line)
• Recording begins and the previous data is kept (2 seconds, as set)
• The Stop condition is met at around 6.5 seconds, hence the trigger indicator (red dotted lines)
• Recording continues for 4 seconds as set
• Enabling the Buzzer will generate a sound when the condition is met. Perfect when moni-toring live data. Can be used without using the automatic recordings feature.
-Favourite Fast Add feature which allows adding live values to favorite list quicker. (new and old
firmwares)
• Click on the star when viewing an ECU live values
1- Click here to create a new list
2- Current favourite lists are shown here
3- Click on the star to add the live value to this favourite list
-Layout improvements (new and old firmwares)
-Selection of which live values to be exported and viewed (logs). (new and old firmwares)
Car Configuration File (new and old firmwares):
-Complete CCF list can be edited upon request.
-Favourite Fast Add feature which allows adding configurations to favorite lists quicker.
ECU Info (new firmware only): This new layout is the basis for what will be the next step reflashing wise. It now shows which ECUs are up to date and those for which a newer version is available. If you are testing this function, please send us the results using the send e-mail button for our records. This will help us validate the automatic file selection algorithm.
An historic of each ECU Info scan is saved and can be recalled.
Tool Activation (new and old firmwares): Initial activation of the IIDTool can all be done within the App when the mobile device is connected to the internet. Additional licences can also be entered in the App.
New French version (except for live values and car config, new firmware only)
Documentation: The user manual was completely overhauled and will be released in the comming days in French and English.
Jaguar support: It is now possible, upon request, to use the IIDTool BT or Pro on 2008 and up Jaguars.
Work on the Android App is still under way. If you are using Android devices only, please do not update to the special firmware 2434 (English), 2435 (French) or 3630 (Pro English), 3631 (Pro French) and up since the firmware is not backward compatible with earlier App versions. You can, however, revert back to the latest beta if Android usage is required after using it on an Apple device.
Our current beta testers using Apple devices can benefit from these new additions by updating the App to V2.9 and IIDTool firmware to:
BT:
-Special Build 2439 (English, French upon request)
Pro:
-Special Build 3643 (English, French upon request)
We strongly recommend updating your mobile device operating system (iOS) to the latest version prior to using the new App and firmware.
As usual, feedback is more than welcome! For those who are not currently beta testers and want to test the new App and firmware simply send us an e-mail or a PM.
Cheers Thumbs Up
Edit: Added pictures and additional comments.
Post #266507 20th Jun 2014 9:59pm
shalz
Kenya 2011 Range Rover Vogue TDV8 Santorini Black
Congrats Pat and GAP team, an improvement to an already great service. Will download the update asap. Hope my one input on TDV8 configuration issue helped and apologies for not being more useful.
On the Android app, if you need a beta tester happy to help out as I'm all Android with no Apples.
Congrats again and thanks for all the support. MY11 Vogue 4.4 TDV8 - "African Queen"
Post #266514 20th Jun 2014 11:32pm
congratulations GAP chaps.. Thumbs Up
How to update:
-Uninstall your current updater software
-Download and install the latest updater software from the following link;
http://www.gap-diagnostic.com/docs/IIDTool_Updater_2_Setup.zip
or for Mac users
http://www.gap-diagnostic.com/docs/IIDTool_Updater_Mac.zip
-Once this is done, start the Updater, connect your IIDTool and click "Find Device".
-Proceed with updating your IIDTool with "Program Firmware"
-Please download and read the user manual before using this firmware version
Post #266525 21st Jun 2014 6:44am
shalz
Updated the IIDTool and used a friends iPad with the new app. Really good updates and now even easier to use and navigate through the menus and options. Also noticed new options available for the car.
Really happy with the new interface and updates.
Thanks guys, keep up the great work. MY11 Vogue 4.4 TDV8 - "African Queen"
Post #266598 21st Jun 2014 5:44pm
Is there one for the non BT tool??? Pete
Post #266610 21st Jun 2014 7:21pm
clarkie
England 2005 Range Rover Vogue Td6 Adriatic Blue
As Pat said in his post will be available for non bt units shortly Thumbs Up
Post #266611 21st Jun 2014 7:32pm
taskam
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Quote:
• ECU Re-flashing (Bluetooth added, 2005 and up)
Sorry to be dumb, but does the Bluetooth reflash mean updating the in-car BT ECU firmware so that it doesn't need the 2121 code every time, and will support phone book display? 2007 TDV8 Vogue SE Java Black
Post #266674 22nd Jun 2014 9:12am
PatGAPInnov
Site Sponsor
Glad you like it! Everyone here deserves a tap in the back, including our customers and beta testers. I'll pass the congrats to all GAP Team members.
Regarding the Bluetooth ECU re-flash, here's a little quote from the IIDTool's user manual:
Updating the Bluetooth ECU on earlier vehicles will improve pairing on more recent mobile devices. It
will also allow phone book access on the radio or navigation screen. It is not necessary to proceed with
this update if these features are already working properly.
Before proceeding, please consult your user manual.
Cheers!
Post #267318 25th Jun 2014 4:24pm
taskam
Excellent! I'm impressed. That in itself saves the cost of BT upgrade. 2007 TDV8 Vogue SE Java Black
Post #267324 25th Jun 2014 4:39pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Sounds excellent!
I was on the beta program for the original wired version... Looks like I need to buy a BT!
EDIT: Well done, guys brilliant work!
Post #267441 26th Jun 2014 12:24pm
PatGAPInnov
Site Sponsor
Thank you!
E-Mail sent... Thumbs Up
Post #267467 26th Jun 2014 2:12pm
Stephen.125
*does grand and entirely inappropriate dance*
Thumbs Up Thumbs Up
Post #267500 26th Jun 2014 4:17pm
jaybear
France
Awesome update and such a customer service .
I must say again how I am pleased with this IIDTool .
I updated to 3.0 , and the user experience is AWESOME !!!
it's even better than it was , this is coming very close to APPLE's standards in terms of user experience !!!!
And as usual customer service is top notch , with fast , reliable , explanatory , most helpful replies and follow-up .
Ptrick is really good and dedicated .
This team needs to be praised . Jaybear
2002 V8 , premier edition , 19" alloys ,
Post #269847 9th Jul 2014 7:54am
Stephen.125
+1 massive thanks to the team.
I updated to version 3 and had a full run through last night tested on both iPad and iPhone 5S. Seamless fast connection and a great UI.
I went through most of the menu options and changed some CCF functions- It's extremely easy and the BT connection is very solid.
Hugely impressed!
Well done to all!
Thumbs Up Thumbs Up Thumbs Up
Steve
Post #269856 9th Jul 2014 9:24am
taskam
Has anyone used the BT IID tool to reflash their BT ECU? I'm interested in doing this. 2007 TDV8 Vogue SE Java Black
Post #269923 9th Jul 2014 12:47pm
