Home > Maintenance & Mods (L322) > OIL LEAK!! |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 |
Don't bring it my house with oil leaking all over my oil free drive.
19th Jun 2014 8:02pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Check the oil filter reservoir as they often spring a leak (if the seals are not changed during servicing) and it drips down that side of the diff |
19th Jun 2014 8:03pm |
Plumber cae Member Since: 19 Jun 2014 Location: Blackwood Posts: 21 |
Will lift it up after work tomorrow, will check that reservoir tomorrow thanks for the tip!! Was thinking about changing the oil on the weekend anyway and I now know the perfect place to do it Jayboy!! |
19th Jun 2014 8:11pm |
2020 Porsche Panamera Turbo Hybrid (V FAST)
19th Jun 2014 8:13pm |
Forgot to mention that I changed out the old style crankcase breather last week for the updated style, wether this has anything to do with it, I doubt it as it's on the opposite side to the leak. |
19th Jun 2014 8:18pm |
Got a pic of your rr then Jayboy? |
19th Jun 2014 8:20pm |
Have a look in my gallery 2020 Porsche Panamera Turbo Hybrid (V FAST)
19th Jun 2014 9:03pm |
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 |
i have a 2002 TD6 and i have a minor leak as you describe which i think is the seal between the sump and diff, £8 for the seal bitch to change so as i dont get any drips just a bit of oil stain around the diff ive not tackled it just wash it off every few months................it leaks less when ive done an engine oil change |
19th Jun 2014 9:14pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
And don't go under your car in off road height without putting an axle stand or two in place, just in case!
19th Jun 2014 9:24pm |
Thanks all, will clean it up tomorrow and have a proper look with the axle stands !!! Will keep you posted! |
19th Jun 2014 9:29pm |
Not an easy fix...... Defiantly the oil sum seal!! Anyone done this before?? Or any advice? Thanks |
20th Jun 2014 6:50pm |
