Home > Technical (L322) > tyre monitoring system fault 2005 S/C
winslo
2005 Range Rover Vogue Td6 Adriatic Blue
Changed the wheels on my supercharged vogue at the weekend, and today i get the flat tyre sign pop up and 'tyre monitoring sytem fault' message on dash.
I didnt think the older vogues had that system on. Is there a way to reset or disarm it?
thanks
Post #265899 17th Jun 2014 4:19pm
87RJD
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Hi, I think you can dis arm using IDD tool, With mine the spare indicated low, I was advised pump it up hard, and put in on the RNS, and go for a drive, warning went off, so swapped it back as spare, no issue since.
Post #265906 17th Jun 2014 4:44pm
