Home > Technical (L322) > P0011 - Powertrain fault
This topic is locked: you cannot edit posts or make replies.  Down to end
jaipal2004
Hi,
got the following code that keeps cropping up when scanning using my ELM ODB2 interface and the torque app:
P0011 - Powertrain
"A" camshaft position - timing over-advanced or system performance (bank 1)
I also have the following but believe these to be LPG related and the car is going in on Thursday in an attempt to solve these:
P0174 - System too lean (bank 2)
P0171 - System too lean (bank 1)
I keep hearing different things - including the infamous VANOS unit .....
Any tips on where to go / what to check guys?
Cheers Very Happy
Post #265847 17th Jun 2014 8:53am
you have posted this already here http://www.fullfatrr.com/forum/topic25583.html?highlight=p0011 please do not double post. ... - .- -.
Post #265850 17th Jun 2014 9:16am
This topic is locked: you cannot edit posts or make replies.  Back to top
