Home > Maintenance & Mods (L322) > Coolant leakage
Trossachsturbo
Scotland 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Coolant leakage
Just bought the 2002 4.4. Up from the south,noticed moisture on drive. Dropped splash cover and notice between the rad which is new and the block a plastic Y fitting with 3 of 25mm approx hoses disappearing to the engine and up to a tee of the rad.Do these hoses have O rings on the clip fittings?as one of them is weeping, and before I open it I will try and get replacement parts
Post #264825 12th Jun 2014 8:14am
are you sure its not the air conditioning? ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #264826 12th Jun 2014 8:17am
Trossachsturbo
Thanks Stan,level of coolant was slightly down, water on ground tasted of anti freeze.haven't located compressor yet!!but will have another look
Post #264829 12th Jun 2014 8:23am
that all points to the cooling system Neutral .. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #264831 12th Jun 2014 8:27am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Have a look at this as it could be an O ring.
http://www.fullfatrr.com/forum/topic23001.html If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #264882 12th Jun 2014 11:24am
Trossachsturbo
Wow,thanks welsh dragon ,exactly the problem will head off to find the O ring.thanks again, just what this forum is so good at!!,
Post #264886 12th Jun 2014 11:33am
Welshdragon
Thumbs Up Thumbs Up
Glad to help, hope you get it sorted, easy job to do. If it dont work.......burn it!
Post #264901 12th Jun 2014 12:38pm
