Home > Maintenance & Mods (L322) > More problems .... now transmission .((
Needle
2003 Range Rover SE Td6 Java Black
Hopefully some one will be able to provide a simple solution but i doubt it lol .(,
Ok so I have a 2003 td6 l322, and I've got a issue with my box , basically hot or cold makes no difference , if i engage 1st in the auto box (sport or normal)it wont move just revs,however if i put it manual mode it moves then i can flick it back over to auto and it drives fine until i stop and it goes into 1st then i have to do the same again with going into manual .
any help advice would be great folks .(((
Post #254446 14th Apr 2014 7:29pm
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
Sounds like a freewheel issue, although must admit I'm not familiar with that 'box. Could be expensive, I'm afraid ... Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #254462 14th Apr 2014 9:44pm
Needle
Anyone with advice on this ? Is there anyway I can stop the car going into 1st gear in the auto box for the moment till i get another box?,so it just goes to 2nd and the rest of the gears?
Post #264226 9th Jun 2014 5:09pm
RRPhil
As I said over on rangerovers.net, it’s most likely the low clutch sprag that’s gone. http://www.rangerovers.net/forum/6-range-r...post758698
You’re fortunate with the TD6 in that you can manually select 2nd gear from rest. The 5-speed V8 won’t allow you to manually select any forward gear other than 1st when stationary in high range.
Phil
Post #264239 9th Jun 2014 6:16pm
Needle
i cant get 1st at all ?, im looking for another box /supplier in scotland at the moment but was just wandering if theres anyway i can stop the box trying to shift into 1st for the mean time to save flicking into manual each time
Post #264245 9th Jun 2014 6:26pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
needle, not much help but mine does exactly that for about 100yds then engages, I park facing the house and it only seems to happen when I select reverse before D, I will have to have a look as maybe it is missing first and going into second after 100 yds, only when cold Confused
Post #264258 9th Jun 2014 7:34pm
Rosco
Phil, whats involved in the clutch sprag issue. should i get it sooner than later as just living with it at the moment as not a problem for me ( not the car ) Thumbs Up
Post #264260 9th Jun 2014 7:50pm
