![]() | Home > Maintenance & Mods (L322) > More problems .... now transmission .(( |
Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 190 ![]() ![]() ![]() |
Sounds like a freewheel issue, although must admit I'm not familiar with that 'box. Could be expensive, I'm afraid ... Regards,
Needle Member Since: 07 Dec 2012 Location: Aberdeen Posts: 51 ![]() ![]() |
Anyone with advice on this ? Is there anyway I can stop the car going into 1st gear in the auto box for the moment till i get another box?,so it just goes to 2nd and the rest of the gears? |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
As I said over on rangerovers.net, it’s most likely the low clutch sprag that’s gone. http://www.rangerovers.net/forum/6-range-r...post758698
i cant get 1st at all ?, im looking for another box /supplier in scotland at the moment but was just wandering if theres anyway i can stop the box trying to shift into 1st for the mean time to save flicking into manual each time |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2587 ![]() ![]() ![]() |
needle, not much help but mine does exactly that for about 100yds then engages, I park facing the house and it only seems to happen when I select reverse before D, I will have to have a look as maybe it is missing first and going into second after 100 yds, only when cold |
Phil, whats involved in the clutch sprag issue. should i get it sooner than later as just living with it at the moment as not a problem for me ( not the car ) |
