![]() | Home > In Car Electronics (L322) > 2014 - New Head Unit for Range Rover 2002 to 2004 |
alahmed Member Since: 03 Jun 2012 Location: Jeddah Posts: 62 ![]() ![]() ![]() |
Note : all the below issues has been solved , the version 2 of the same head unit is working perfectly without any issues (28-8-2014).
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7905 ![]() ![]() ![]() |
I think IR could be infra red for the remote control ?
Ah, says HSE in his car profile, so one would imagine it would be fairly simple to do - compared to the Vogue DSP setup..... 2011 Range Rover Vogue SE 4.4 TDV8
iphs Member Since: 07 May 2014 Location: Norfolk Posts: 198 ![]() ![]() ![]() |
I would be interested in that head unit if it could be wired in to replace the old non-touch screen head unit in my 2003 Vogue.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
@jonboy
Just having a wonder, I am assuming the model designations are the same as the UK market, and they could well not be. I know over in the US the top spec model was badged HSE and had the screen in as standard. So over in the Arab States it could have the screen as standard.
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
Looks very similar at the back to the one I fitted also the looms and plugs on the 5m was different (it is a universal fitting kit)
Thank you mjdronfield for the information |
Dear johnboyairey my car is 2004 HSE with DSP (not logic 7 system) and Navigation screen the price for the sample was 550 USD and for big orders it could be 300 USD. maybe the price now is different , but you could check with Miss. Brianna ( her email was included in my 1st post) as i have mentioned before its the 1st unit they ever made for Range Rover. Thank you |
unfortunately mjdronfield its a DSP setup |
Replacing the outdated none touch screen with the mentioned head unit or any other aftermarket head unit is always possible as i think. i am searching currently in those subjects about working-around DSP. in the fact even if the price is removing the old system completely i believe its worth it. Thank you |
mjdronfield you are right Saudi specification for 2004 HSE Range Rover include all the option except the Logic 7 sound system and the heated seats. if i understood you well i think this head unit is a replacement for the both. |
In the UK, the HSE does not have the screen as standard, it had to be ordered as an option.
Thank you IronHorse are you having the user name on rangeroverd.net? if yes the there is private message waiting for there since yesterday. i will be waiting for your notes and you help. anyway i have connected the unit to the back of the car to see it working or not. there was not sound because DSP was off since i disconnected the BM54 Radio ( its was normal). the only problem i have noticed was the green back led light kept turning off for one second every 20 seconds see this video Range Rover (2002 to 2004 android Head Unit http://www.mediafire.com/watch/esobcbtooorf6un/Project%201.wmv Last edited by alahmed on 9th Jun 2014 6:28pm. Edited 1 time in total |
