Home > Maintenance & Mods (L322) > Compressor refurb
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Compressor refurb
Guys
Can anyone confirm,,, My 2004 suspension is real slow at raising. I'm getting no messages on dashboard and the car does not drop over any time. Hence I'm driving it around at the same height with no issues.
It does go up over about 3 mile if I change the height.
I've just brought the kit to refurb it but the guy is saying that it will proberly need to go on diagnostics after as it may recognise the pump was disconnected.
Anyone done theirs and know if it does or doesn't?
Cheers
Tel Accept, some days your the pigeon, some days your the statue!
Post #263879 7th Jun 2014 5:17pm
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
As long as you don't turn the ignition on whilst it's disconnect you'll be fine.
Jonno 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #263886 7th Jun 2014 5:57pm
Boydonegood
Cheers Jonno
Is it worth trying to fit the seal without disconnecting the wire plug too or leave ign off should be enough for it not to throw an error message up?
Thanks mate
Post #263887 7th Jun 2014 6:04pm
Jonno
it will only throw up an error if it can't detect the pump or raise the suspension......so put the keys in your pocket and uplug it. 5.0 supercharged autobiography
Post #263888 7th Jun 2014 6:27pm
Boydonegood
Thank you fella
Job for tomorow then Wink
Cheers. Tel Accept, some days your the pigeon, some days your the statue!
Post #263908 7th Jun 2014 9:05pm
Boydonegood
Thank you Jonno.
To confirm what you said. Keys in pocket and the refurb goes smooth with no errors. Your a star. Done refurb today and have working Susp again!!
Thank you Accept, some days your the pigeon, some days your the statue!
Post #264737 11th Jun 2014 7:01pm
