![]() | Home > Maintenance & Mods (L322) > Air con condenser removal |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35675 ![]() ![]() |
5 minutes after posting and its in the wiki, boy i'm on the ball today |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
Thanks Stan |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 ![]() ![]() |
Nice job Welshdragon, its sure to help others. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
My job this week, will let you know how it goes |
if a numpty like me can do it tim then i think you'll have no problems.. ... - .- -.
Simples to do TIM, won't take you long, the hardest part was finding the tools my dog nicked! |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
Just a point to note that it is illegal to release the gas from the aircon into the open atmosphere. So unless you know that the system is completely empty you should take your vehicle to be de-gassed prior to opening up the aircon system 56 TDV8 Vogue SE
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
^ just beat me to it. There was obviously gas in the system as it was still working.
NO garage will fill the air con system up when a leak has been detected, no matter how big or small it is, well a good garage wont. I have eddited as some on here might not know about de-gassing. If it dont work.......burn it! If the IId tool cant fix it.......burn the FF. If the FF cant be fixed......buy a Land Cruiser! If the LC cant be fixed..............................................BUY a horse !! |
I put the ffrr into an air con specialist to find out what was wrong. I also checked with them that it was empty and safe for me to replace my condenser.
I didn't do mine, just the condenser as those brazed pipes where the problem, the lower one been the worst. If it dont work.......burn it!
@tim, is the dryer not part of the condenser? [right side as you look from the front] ... - .- -.
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 ![]() ![]() ![]() |
cool might give mine a go soon |
