Home > Technical (L322) > zf box
Bozzy1954
England 2003 Range Rover HSE 4.4 V8 Epsom Green
zf box
anyone tell me where I can find a gear display sensor? and what it does, this part seems to be the cause of my problems. Its a zf box. cheers.
Post #263598 6th Jun 2014 10:36am
can you update your car profile so we know what year/model you have..
also there are WM downloads in the wiki if it helps but i'm sure someone will help once we know what you have.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #263603 6th Jun 2014 10:46am
RRPhil
Do you mean the inhibitor switch (sometimes called the XY switch or the selector switch)?
This switch tells the transmission ECU which gear position has been selected by the driver and the signal is sent on to the dashboard display. The standard DTC for a fault with this component is P0705. Second-hand ones regularly appear on eBay for anything between £100 and £200, though it’s easy enough to test its function before you spend any money :
Continuity test with +ve pin :
Note that the wiring or connectors on Jaguar and BMW (including the X5) switches - which also use the ZF 5HP24 - are different. Only a specific Range Rover switch, with the longer wires, will fit. The ZF part no. is 0501 319 191 and the Land Rover part no. UHB 500020.
Phil
Post #263684 6th Jun 2014 4:21pm
Bozzy1954
To be honest Phil I don't know, I'm going on what the mechanic said, he said the part from Landrover was £470 and it controls most of what happens in the box, I will speak to him today and show him your post.
Post #263774 7th Jun 2014 7:33am
Bozzy1954
Spot on Phil thats the part thats gone, looked on e-bay a choice of 3 alot cheaper than Land Rover. thanks for your help.
Post #263999 8th Jun 2014 1:29pm
