![]() | Home > Technical (L322) > Hydraulic Engine Mounts -Info and Advice Needed |
Bit touchy this morning are we. |
You forgot the battery disconnect /reconnect but otherwise you have everything covered. |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
My point was that i had a vibration issue and initially they thought it was the injectors, then mountings then finally TC.
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
nicedayforit and paulb... |
All I need now is one |
Finally managed to get underneath today to have a look, after spending ages removing the engine undertray...20 ruddy bolts to take off to get the damn thing off.
Okay, time for an update and a request for some info.
Have you checked the Torque Converter for valid post 900RPM Vacuum assistance delay? |
^ Sorry Gaz, you totally lost me there...
TC joke |
^ DOH!! |
You will get there and as you say the vibration source is varied and far too common on TD6's. |
RoyMacDonald Member Since: 18 Aug 2014 Location: Rye East Sussex Posts: 8 ![]() ![]() ![]() |
Did you have it laser aligned when you had the tyres done? It should be checked every time you have any work done on the suspension, brake disks, new tyres and at least once a year from my experience. The rear being out of alignment can affect the feel of steering.
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
I was about tom leap in and say of course vacuum drops as revs rise, dont you remember vacuum wipers or Triumph PI vacuum tanks. But I recalled this is a TD6 not petrol so thought I had better shut up. |
