Home > Technical (L322) > Hydraulic Engine Mounts -Info and Advice Needed
Page 3 of 3 <123
jumbaleo
Did you get to the bottom of this fault please? I believe I may be experiencing something similar on my 2007 3.6 TDV8
Post #301264 28th Dec 2014 12:53pm
clemenz
Austria 2006 Range Rover Vogue Td6 Zermatt Silver
any news on that? i have some weird failure which shows sometimes. now the engine is "shaking" when i power it off, sounds like the visco unit is touching somewhere... its also a td6
Post #318491 17th Mar 2015 7:19pm
Discotigger
Never managed to get to the bottom of the mysterious vibration, just got used to it on the FF. I have had the FF in to a few places to look at the engine mounts, hubs, wheel bearings, etc., ... even the servotronic valve (which the garages involved have not swapped out for a new one, as requested by me, instead claiming it's 'something else than that').
Just wish I had a decent double garage at home, so I could get under the FF (safely and with a bit of space to work), rather than just putting up with the vibration. But, HEY HO...At least it's definately not the TQ at fault Whistle
Post #318496 17th Mar 2015 7:50pm
clemenz
ok, i see. i have an appointment at an indy end of the month, we will see...
Post #318504 17th Mar 2015 8:39pm
Page 3 of 3 <123
