![]() | Home > Maintenance & Mods (L322) > Aero Front Windshield Wipers Fitted |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
that would be interesting |
Advanced Factors Site Sponsor Member Since: 31 May 2013 Location: Southampton Posts: 198 ![]() ![]() |
In fact, thinking further, I will order an OE Arm into stock then I can find the best fit without hassling anyone! Paul Redding
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 ![]() ![]() ![]() |
Fitted a set today and they seem to do the job - time will tell if the clip is up to the job. |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 ![]() ![]() |
Seems loads of members are giving these wipers a try. Mine are ok for the mo, but these do seem good. |
they do seem good..i'm waiting to see if steve @ AF comes up with a better deal...buying from a site sponsor seems like a good idea |
Good idea will wait also.get them out for the lads Steve |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8392 ![]() ![]() ![]() |
Mine got a good work out today, work just as well as the Bosch ones, the retainer for the wiper half way down the arm is now redundant as it doesn't reach the new lower profile blade but the blade moves smoothly and doesn't fish tail, they are noticeably quieter on the screen and less wind noise, took them to a fast speed |
Any increase in mpg? Present :2008 TDV8 HSE
Said 74.6 on the way home but I don't believe it!!!!!!! Pete
you use this special tool,
If the hammer fails, there are two parts to the clip, you have to squeeze both sides in on the underside of the arm to release the clip from the holes on each side, doing this snapped mine into several pieces.... Then there is another bit that just pulls out.... Basically you don't want any plastic bits left on the end of the arm... Pete
any news steve? ... - .- -. Y. O. L. O. . |
Not yet Stan, arm should be in today then I will investigate. Paul Redding
