Home > Maintenance & Mods (L322) > Air Con Pump, removal advice.
iphs
England 2003 Range Rover Vogue Td6 Buckingham Blue
I need to replace the air-con pump with a new one on my MY03 TD6 Vogue. Dealer quotes are a joke (pension won't stretch that far and the wife refuses to go on the streets), so going to do it myself.
I have transplanted, rebuilt and repaired plenty of engines over the years, so this does not faze me at all but a little advice from anyone who has done it would be very welcome.
The system has been de-gassed (by the experts) so I am pretty much ready to get on with it.
A couple of questions before I start:
Can the pump be removed from under the vehicle or should I remove the fan and radiator and go in from the front.
Any advice will be appreciated. Thumbs Up
Post #262356 30th May 2014 6:06pm
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
http://workshop-manuals.com/landrover/l322...essor_td6/
the manual suggests go in from the front
Post #262357 30th May 2014 6:31pm
iphs
Hi SoggyBottoms, Thanks for the reply.
I did see that in the manual but was hoping that someone had done the job from below the vehicle.
I have had a look from below and can access everything that needs to be undone, just can't be certain that there is enough room to drop the pump ouy.
Post #262365 30th May 2014 7:37pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
I removed mine for a rebuild a few months back. (Must rebuild it soon!)
I took mine out from underneath. Only thing I removed was the splash pan.
You can get the hex fixings on the pipes from the top with a couple of long extensions and a flexi head.
Post #262370 30th May 2014 7:58pm
iphs
Thanks Paul, that was the answer I was looking for Thumbs Up As I said above I was having a good look at it and thought it would be possible and easier.
Post #262382 30th May 2014 9:26pm
paul271
If I remember right mate there's a bit of jiggling but it comes out no bother.
Post #262385 30th May 2014 10:44pm
