![]() | Home > Technical (L322) > Engine Change on Td6 |
If the motor is from a RR, it should be plug n play AFAIK. Adaptive values for the Injectors should be reset for best performance. Can be done with a LR OEM T4 - coming on the IIDTool. |
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 167 ![]() ![]() ![]() |
@ Dazzler, brave steps you're heading for! Just curious: why do you do a swap? These should be robust engines altough mine has had a rebuild (previous owner |
Dazzler Member Since: 09 Sep 2013 Location: West Sussex Posts: 34 ![]() ![]() ![]() |
Engine has a hollow tapping noise from no 5 cylinder possible cracked cylinder or Burnt out valve? lack of power loads of black smoke with a constant missfire. Injectors all checked bt Specialist all ok. Just as easy to change the engine complete. This is engine no 2. First one was a recon short block. |
Wow, no luck for you then |
The adaptive values are adjusted automatically over time and stored in the ECM. The engine will run without the adaptive values being cleared, but it will run better if the ECM can adjust the values from scratch as it sees fit.
