![]() | Home > Technical (L322) > Head gasket TDv8 |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 ![]() ![]() |
Yikes, sorry to hear of your woes, hope its sorted for you soon.
Better check your oil and ATF. A ruptured cooler shows similar issues.
Ide be checking many many other things before the HG my friend... Not a common issue at all! Have you had a very good mechanic (who knows these engines) look at it? There are so many things to check before condemning HG... Have you simply bled the system properly? Because they can be |
RRD Member Since: 19 Mar 2014 Location: Antwerp Posts: 40 ![]() ![]() ![]() |
It's hard finding a good mechanic who knows these engines in Belgium. I'll probably take it to the dealer tomorrow, and let them check it... '17 Range Rover 5.0 Supercharged AB (Sold)
