Home > Technical (L322) > Head gasket TDv8 |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 |
Yikes, sorry to hear of your woes, hope its sorted for you soon.
25th May 2014 7:45pm |
Better check your oil and ATF. A ruptured cooler shows similar issues.
26th May 2014 12:39am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16230 |
Ide be checking many many other things before the HG my friend... Not a common issue at all! Have you had a very good mechanic (who knows these engines) look at it? There are so many things to check before condemning HG... Have you simply bled the system properly? Because they can be to bleed!!! And as Eugene says above, check the ATF & EO coolers before going any further... |
26th May 2014 10:59am |
RRD Member Since: 19 Mar 2014 Location: Antwerp Posts: 40 |
It's hard finding a good mechanic who knows these engines in Belgium. I'll probably take it to the dealer tomorrow, and let them check it... '17 Range Rover 5.0 Supercharged AB (Sold)
26th May 2014 11:25am |
