Home > In Car Electronics (L322) > Koolertron touchscreen upgrade in RR2003 Vogue, no sound
Page 2 of 3 <123>
this is a you tube video re another chinese unit but the 'plugging in' might help you sort the problem,
no doubt there are other videos on the tube that might help.. ... - .- -.
Post #260296 19th May 2014 3:18pm
mjdronfield
Mmm.
The video posted by Stan shows the connections being done at the front of the car, but then thats an HSE without the extra amps in the boot......
What connections do you have at the front of the car, behind the screen ?
Do you have masses of lead length thats meant to reach as far as the boot ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #260301 19th May 2014 3:32pm
AndyBunn
The connecter on the right has funny prongs that don't seem to go anywhere as per picture and black wire is cdc-gnd,red wire is cdc-r, white wire is cdc-l
http://www.fullfatrr.com/gallery/albums/us...5B1%5D.jpg
Post #260349 19th May 2014 7:26pm
AndyBunn
Hi Stan I have seen this video. , The only wires I have in the front is a white plug and a blue plug into the back of the original head unit.
The wiring loom I have been sent will reach about a RR and another half. I thought I would try getting it working before I start feeding it through the interior.
many thanks http://www.fullfatrr.com/gallery/albums/us...5B1%5D.jpg
Post #260351 19th May 2014 7:32pm
AndyBunn
HI MJdronfield/stan,
on my new harness the block on the far left has four wires sticking out. I have checked this with the wiring diagram previously posted.
no. 10 no.11 which are phone
no. 12 ground,
no.15 live,
Would it be silly of me thinking these are not important. or are these vital. im thinking that ive been stupid and I need to connect these somewhere. what do you think ????
Post #260361 19th May 2014 7:50pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
Andy
been there done that
if it has the better sound system as standard with the black amp in the boot(from the photos you have) and the non touch screen satnav the new radio will not work without a little modification
to start with it looks to me you have the wrong loom for the vogue , you need the fully populated fakra connectors where all 40 pins are used
ok also the amp in the boot will only switch on with the OME display screen plugged in (its canbus operated)
dont forget the range has NO aux feed to the OME tuner in the boot so there should be a red fly lead you need to live up on the new radio loom to get aux power to the new radio.
so plug the new radio 40 pin connector into the plug that came out of the silver tuner box in the boot plug in the OME screen white and blue connectors and after about 20 secs it should switch the amp on and work.
i removed the CD changer and put the old head unit in its place (about 5 years ago ) but im sure there would be a little box of tricks available from somewhere to fool the amp into switching on if you did not want to put the screen in the glove box.
its well worth the end result stick with it
nige
Post #260376 19th May 2014 8:59pm
mjdronfield
Excellent. I knew others on here had done something similar, but not having done it myself, was on the edge of guesswork, which doesn't always help.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #260379 19th May 2014 9:03pm
ironhorse
ill post some more info when i can find what i have done with it
nige
Post #260386 19th May 2014 9:15pm
AndyBunn
Hi guys thanks for all your help. I have managed to get it going.
Heres how looking at my first pictures .
The block connecter on the left had to have the white sub connecter from the cars bm54 loom. Then the live and earth from the left connecter fed into no.12 ,no.15 into the middle connecter.
Then connect the left block into the bm54 module. Then connect the middle block to the cars loom.
Then connect the antenna to the little connection on the bm54 module.
I left the original head unit attached and turned them both on had to adjust volume so new stereo was the same volume.
I have disconnected the white and blue cable on the other module thinking that these were the leads to the head unit but the old unit still has power I will try and disconnect the old one when I have a little more time and see if we can get rid of it altogether.
I will keep you updated on my progress
Surprised Thumbs Up
Post #260552 20th May 2014 7:04pm
mjdronfield
Great news.
Had a feeling the little sub plugs had to be moved about.
So it's plug and play, provided you plug and unplug the right cables into the right places......... Whistle 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #260555 20th May 2014 7:25pm
AndyBunn
I have removed the old unit completely and still the new head unit works......
Now to disconnect it all and start feeding all the cables through the interior. I think I will be looking for clues on internet to see the best way to strip the interior.
cheers everyone
"plug'n'play is the way forward
Bow down
Post #260739 21st May 2014 7:39pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Does the original head unit not control the clock on the dash and a couple of other bits and bobs. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #260742 21st May 2014 8:01pm
mjdronfield
Not sure about the other stuff, but you can set the clock by taking the fuse out and putting it back in at 12 o'clock, as that's what it goes to on a reset......
You may only have to do that twice a year when the clocks change. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #260743 21st May 2014 8:04pm
iphs
England 2003 Range Rover Vogue Td6 Buckingham Blue
I like the look of that head unit and would love to upgrade my non-touch screen unit. However even with all the information in this thread I am still at a complete loss.
I hate being a useless Censored Crying or Very sad
Post #260749 21st May 2014 8:33pm
AndyBunn
Hi Rej. I didn't notice the clock stopping. but the loom comes with a little magic canbus box which makes all the steering wheel controls work.
Iphs, I will upload new pictures once it is installed and wired through the car. after all the threads and conversation with mjdronfield it is not to hard.
Post #260979 22nd May 2014 7:35pm
Page 2 of 3 <123>
