Home > Maintenance & Mods (L322) > Air Con is STILL NOT WORKING |
iphs Member Since: 07 May 2014 Location: Norfolk Posts: 198 |
I understand what you are saying. However the car is 11 years old, i don't know if its ever been re-gassed. I have only had it a week so i ghog.etting to grips with it. When I tested the air con on a test drive it seemed to work but it was a fecking cold day.
18th May 2014 7:40pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
18th May 2014 8:04pm |
18th May 2014 8:17pm |
Thanks for the thumbs up Gazellio @ Prestige Cars.
18th May 2014 8:29pm |
After that amount of time the gas could have indeed very slowly passed the seals (that have become more brittle over time anyway). So a re-gas for 33 GBP is not a bad strategy and if it then is going low after a short period of time, go for the full monty.
18th May 2014 10:24pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
soon after I bought mine, I had a kwik-fit regas, and it leaked out, in about a month. left it alone for a while. I then spent some more dough calling in a mobile air specialist. he dyed it, sniffed it, gassed it, and his gas went the same way. I then thought I should just change the condenser and the pump. so I searched ebay and got a new condenser for £90 and a secondhand pump from a v8 bmw x5, for just £35. -a flook! -I could have bought a new pump for about £250 I changed then both. whilst changing my water pump. it looked like my air pump had oil and grease from leaks, down the left hand side, so was probably the culprit. another kwik-fit pump up and its good for about 6 months now! |
18th May 2014 10:26pm |
Actually, this is not true, Gaz. An auto AC is more or less the same thing as a refrigerator - only it runs in a much harsher environment (vibration, temp, road salt on aluminum parts, etc). Refrigerators run for 30+ (or even much longer) years w/o issues. Car ACs should do the same - unless they leak. I was involved in the installation and service of auto ACs for 6 years - a leak as slow as you describe (6+ months) is the absolute exception. 90% of all non-working ACs due to refrigerant loss will not hold refrigerant after a re-gas more than a week or 2 at best. And as such, a re-gas w/o a very thorough leak check is a waste of money and taxes the environment unnecessarily (even R134a depletes the ozone layer) in 90% of all cases. And many cheapo Kwik-whatever places make money by duping customers with 're-gas' special offers. Especially because finding a small leak can be a real challenge (= very time consuming). I'd take the car to a specialist who knows what he is doing. In the long run its better for your wallet and the environment. RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
19th May 2014 7:04am |
OK I have been lucky then because mine has remained Freezing for months now.
19th May 2014 7:39am |
^+1 @ Steve:thumbsup:
19th May 2014 7:45am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35271 |
leaks are normally caused by a damaged condenser because it sits right at the front of the engine bay and is prone to stone damage.
19th May 2014 7:57am |
pia1361 Member Since: 24 Apr 2012 Location: guildford Posts: 19 |
If it is the condenser which goes what sort of money should i be looking at to replace it ?
19th May 2014 1:38pm |
i'm not that mechanically minded but i replaced mine on my old td6 and it took about 4'ish hours ..cost of condenser was around £170 of ebay... ... - .- -.
19th May 2014 2:03pm |
Had the RR in for re-gas, didn't work. Got a major leak they say. No time for them to look at it today and no charge for the test.
19th May 2014 4:11pm |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 |
Sounds like you have definitely found a major leak.
19th May 2014 4:21pm |
