Home > Technical (L322) > Gearbox Help needed
Page 4 of 4 <1234
ebajema
Glynn, I agree with you that it is not guaranteed that the problem will be resolved by just replacing the solenoids. However, considering the only fault coming up is the 3-4 shift problem, I think it is fair to say that there is a big chance that a new solenoid set would resolve the problem. If not, it is not a lot of money lost, compared to the complete mechatronic replacement or recon box. At least that is how I reasoned and luckily I was right (when I say me, that is me and RRPhil of course, who gave me a lot of help).
Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy MY 2010 5.0 SC Galway green and sand interior!!
Post #231502 26th Dec 2013 5:59pm
Glynn
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Yes but a new mechatronic isnt that expensive, then theres the fluid to take into account too.
If it were mine it would get a new mechatronic and be done with it.
Post #231505 26th Dec 2013 6:26pm
ebajema
For info, the solenoid change solved the problem with another member having the same 3-4 shift error code. MY 2010 5.0 SC Galway green and sand interior!!
Post #232041 30th Dec 2013 7:01pm
Just for info, and i know its an e60 bmw but there is a vid of how to remove the mechatronic here
http://www.bimmerfest.com/forums/showthread.php?t=654634 There is nothing that can't be fixed with a hammer😜😜
Post #232091 31st Dec 2013 9:05am
Av_dave
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Just an update gents I've got a gearbox man looking at it thurs/fri this week. Will let you know what he finds. It's going to be the mechatronic unit I think from the more you guys have informed and the more I have looked into it.
Thanks Dave The difference between theory and reality is that in theory it will work.
Post #232096 31st Dec 2013 10:18am
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Good luck, Dave. There's a chance that it's not as bad as you first thought!
Do keep us posted.
HNY to all Thumbs Up 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #232219 31st Dec 2013 10:44pm
SKOT
Dave,
What was the outcome of this? Are you sorted? 2006 4.2 SC
Post #236814 24th Jan 2014 1:27pm
Av_dave
It's still been worked on. I've been away with work then holiday so will catch up with the shop on Monday from my last conversation with him it was pointing to a new gearbox. The difference between theory and reality is that in theory it will work.
Post #236860 24th Jan 2014 5:06pm
Av_dave
Just an update for everyone. The car is coming back tomorrow. It's all done. In the end it had a full gearbox recon TC, Mechatronic unit, some plates and other parts I have forgotten. I decided to bite the bullet and just get it sorted so I will never have an issue again with the box. Two water pipes at the back of the engine where leaking as well so they have been changed. The guy commented today after his test drive how well she goes looking forward to having her back tomorrow.
Thanks. The difference between theory and reality is that in theory it will work.
Post #238338 30th Jan 2014 9:37pm
Glynn
Glad you got it sorted Dave.
And the big question £?.
Post #238344 30th Jan 2014 9:44pm
Av_dave
£3900 for the work, all in I had a rad changed and it all serviced as well. Which isn't cheap but the guy who has done it is very skilled and I trust his work. I think that's one of the most important factors.
Dave. The difference between theory and reality is that in theory it will work.
Post #238347 30th Jan 2014 9:54pm
refqi
Jordan 2006 Range Rover HSE 4.4 V8 Baltic Blue
Please can anyone help me to find the kit repair for the valve body 6Hp
Post #260067 18th May 2014 12:22pm
holidaychicken
JPAT are probably the best for ZF
http://www.jpat.co.uk/94%20ZF%206%206HP26%...d%204D.pdf
also used sussex auto parts in the past that were very good and also rebuilt my torque converter although i would still say JPAT as having the best knowledge on ZF.
http://www.sussexautos.co.uk/contact.php
Post #260138 18th May 2014 7:35pm
refqi
Thanks for your help Thumbs Up Thumbs Up
Post #260181 19th May 2014 6:02am
holidaychicken
no bother Very Happy
Post #260182 19th May 2014 6:27am
Page 4 of 4 <1234
