Home > Technical (L322) > Front Heated Seat Not Working...
Andy B
I had this issue as well. Drivers seat no worky, but _/ lights on ok. I have only just got the 2010 car, having previously had a 2006 model. So, I downloaded the firmware update for the IID from GAP and registered the car. After a first pass 'clear all ECU faults' I tried the heating and cooling and hey presto it is now fine. Unfortunately I didn't capture the fault code (doh!).
Brill customer service from GAP as well Very Happy
Cheers,
Andy SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #259935 17th May 2014 3:53pm
mzplcg
Just to confirm, on my old car which was an 07 Vogue SE the heated & cooled seats do indeed have electrical heaters. I replaced one when I did the driver's seat base foam. The cooling is piped in from the air-con.
If the heater element is knackered then replacing it will require a pair of hog ring pliers to release the leather and for the sake of 40 quid you might as well replace the seat base foam while it's all apart.
Dom
Post #259942 17th May 2014 5:00pm
