Home > Technical (L322) > Front Heated Seat Not Working...
Bomber County
England 2007 Range Rover Vogue TDV8 Java Black
Hello all,
For some reason my front heated seat (drivers) has stopped working. All the lights come on the button when I turn it round and I wondered if there were any obvious 'gotchas' to look into before I get it looked at properly.
Cheers, Bomber. - Ad augusta per angusta -
Post #154173 28th Nov 2012 8:49pm
first port of call would be to check the connections under the seat and the relevant fuse.. ... - .- -.
Post #154176 28th Nov 2012 9:02pm
Stan, if the lights go on then all is connected correctly...
Craig Thumbs Up
Post #154246 29th Nov 2012 12:43am
ok Craig Bow down , i thought that the lights might work but if the under seat connection is loose/faulty then it wouldnt work...
seat element gone then? ... - .- -.
Post #154263 29th Nov 2012 9:16am
Bomber County
right fellas that sounds like a start, thanks v much. - Ad augusta per angusta -
Post #154485 30th Nov 2012 1:13pm
If all seems ok, test the continuity or resistance of the element using a multi meter, this should tell you if the element is bust. It should show continuity and give a resistance figure. If it doent its not making a circuit hence wont work. New element time. There is nothing that can't be fixed with a hammer😜😜
Post #154669 1st Dec 2012 10:25am
taskam
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Bomber, did you find the cause of failure? I have similar fault on mine. Lights work, fan runs continually for couple of minutes, then stops. No heating or cooling. Was a replacement unit installed by main dealer about 4 years ago. 2007 TDV8 Vogue SE Java Black
Post #191944 4th Jun 2013 8:33am
GraemeC
Per his signature, Bombers car is a Vogue
Vogues have heated seats, but its a heater element in the seat. Vogue SE has a heated air system
Whilst I'd like to see the resolution to Bombers problem (always useful for people!) the solution for the VSE may be different... 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #191952 4th Jun 2013 8:51am
taskam
Thanks Graeme, good spot. indeed you are correct, it's a heated /cooled air system that I have.
Anyone experience this failure? Lights on the control illuminate ok red / blue for heating / cooling. The (seat) fan runs continually for couple of minutes (normally it cycles on and off every few seconds) then stays off until ignition is cycled.
Thanks. 2007 TDV8 Vogue SE Java Black
Post #191970 4th Jun 2013 10:17am
mpirie
I have a similar issue with the drivers seat. The seat cooling works fine, but seat heating doesn't.
jpickie posted:
Just had the same problem with mine, turned out to be the temperature sensor in the backrest peltier cell unit which had gone this also made the ecu turn off the seat base heater as well. The sensor is part of the peltier cell which comes as a unit with the fan and duct, was about £180 from Dan and I fitted it myself. IDD tool was very useful in obtaining the fault codes which pointed in the direction of the faulty cell. There are some pictures in my gallery of the set up and offending item with a bit of info regarding the operation of the climatic seats that you may find useful.
So we're not alone Big Cry
Mike
Post #191989 4th Jun 2013 12:26pm
taskam
Thanks for the link mpirie, and jpickie for the info. Will have a look into the seat gubbins when i get a chance. 2007 TDV8 Vogue SE Java Black
Post #191997 4th Jun 2013 12:55pm
Arenaitch
Got these same symptoms on my 9m old Westminster, right after I've just had a loom issue found/fixed - I also thought it may have been simply a tugged connection, seems not though.
Will be interested to see what this turns out to be. 2012 FFRR Westminster Orkney / Ivory and absolutely no pimp-glass!
Post #192007 4th Jun 2013 1:30pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
Same problem here in mine Big Cry Driver's seat cools ok and both red and blue lights work fine but it doesn't heat up.
The car is booked in for a service in the next couple of weeks so will see what they have to say Rolling Eyes
Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #192013 4th Jun 2013 2:41pm
Arenaitch
My "lights are on but nothing happens" was apparently a "short in a motor under the seat' - whatever, it's fixed now. 2012 FFRR Westminster Orkney / Ivory and absolutely no pimp-glass!
Post #198630 12th Jul 2013 7:46pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
I found my drivers seat will heat if you select backrest only (immediately after turning the heat on), and cool both backrest and base without issue. If you just turn on the heat without selecting backrest straight away it has a sensor issue that makes the ECU cut the seat out. Turns out that heating is closed loop monitoring and cooling is open loop so cooling doesn't get temp monitored.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #198787 14th Jul 2013 12:41pm
