Home > Maintenance & Mods (L322) > Rubber bumper bar
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
Rubber bumper bar
Hi,
I have the rubber bumper bar on my beast and was looking at where to put my driving lights(Fyrltr) and a cb ariel on it.
When looking underneath the top section,it has 4 grommets(2 each side) that have a metal screw in section.
The grommets are under the "A" (range) and the "E"(rover)
Can anyone tell me what these are for.
Thanks
Post #258882 12th May 2014 5:55am
psgk
Hello there
I have the same set up and have mounted the LR Driving Lights to the A-Bar which I have had sprayed up in body colour (Java Black)
The LR Driving Light kit came with two shallow "U" shaped metal brackets. These are screwed into the mounting holes in the underside of the A Bar and the Lamp Assembly slides onto them. The Lamps are held in position by two set screws on each Lamp and these are hidden by a small LR branded name plate that clips in place. I cant find a way to fix and lock the lamps in one position. Consequently if I go through a car wash the Lamps are often knocked out of postion and I have to reset them manually.
I hope this helps, good luck. Peter Kemp
Chelmsford
UNITED KINGDOM
Range Rover Vogue MY2002 4.4l V8
Java Black
Charcoal Trim / Oxford Seats
Colour Coded: Door Handles, All Badging Front and Rear, Bonnet Vent, Foam A-Bar / Nudge Bar
Range Rover Style 11 20'' Wheels
US Spec Front Sidelight / Indicator Light Units / Rear Light Units (MY2005 Style)
Retro Fit Sony / Alpine RES
Various LED Light upgraded Interior / Exterior
Lower Rear Tailgate Gas Strut modification
Post #259750 16th May 2014 4:16pm
andy180
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
The best way to do it would be as follows:-
Step 1) Remove the bumper bar/bull bar
Step 2) Throw the bumper bar/bull bar into the nearest skip or alternatively if a skip is not available take it to your nearest local authority refuge plant Thumbs Up
Step 3) Marvel at the front of your FFRR
Step 4) Drive with the high quality bi xenon headlamps
Thumbs Up Laughing Now: BMW 640d M Sport, Alpine White
Gone: Range Rover 4.4 V8 Vogue, Zambezi Silver, Charcoal Oxford Leather
Also: Mk1 Audi TT 1.8T Quattro, Brilliant Black
[URL=]
[/URL]
Post #259774 16th May 2014 6:01pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
Rolling with laughter
Post #259786 16th May 2014 7:13pm
mjdronfield
How did I know that would be suggested ? Laughing
I put one on my Disco 2 and some off road driving lamps, but that was because the standard lights are so bad.
There is one on these on the bay of e, and it looks like the spots mount from above ;
May help....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #259858 17th May 2014 5:49am
littlecub
Thanks psgk,
To the others that say take it off,,nah rather like it.
Just been on to my local landy supplier,its $700 for it...bloody hell(that includes the A bar)
So do any of you know where I could get just the brackets for the lights at a reasonable cost ?? and ship to Australia..
Thanks
Post #260411 19th May 2014 10:48pm
mjdronfield
The Land Rover part number for the driving light kit is VUB001090. This includes the lights and all the electrics. Still around the £230 plus mark though.......
Not sure if you can just get the mounting kit though.....
On this eBay listing, if you scroll down a bit there is a pic of everything that comes in the kit, so you can see the mounts you need to look for, if it helps ;
http://www.ebay.com/itm/LAND-ROVER-SPOTLAM...1150111566 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #260417 20th May 2014 5:36am
mjdronfield
had a further search, the part number for a bumper mounting kit is VUU500020.
http://www.brit-car.co.uk/product.php/9469...0_usa_gcat
Not sure if the do one for the a bar or if this kit can be modded. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #260418 20th May 2014 5:48am
mjdronfield
If you look on the page below,
http://lrcat.com/41/4/50117
There is a diagram with the parts for the lights and some more part numbers. If you look at the blue numbers and then use the table on the left to get LR part no and then do a google search etc.
Hope this helps. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #260419 20th May 2014 5:58am
