Home > Maintenance & Mods (L322) > Another Jack Question
iphs
England 2003 Range Rover Vogue Td6 Buckingham Blue
The scissor jack is missing from my 2003 Vogue. Should I replace it with the same thing or a bottle jack?
Post #259425 14th May 2014 8:11pm
Discotigger
It's a good question!! Aftermarket bottle or LR scissor...
Personally I'd go for the bottle jack..there's a good thread on here about the Merc Sprinter (I think) bottle jacks, worth doing a search on the forum. My old 300TDI Disco had a bottle jack as LR standard kit (stowed in the engine bay!!), so can't understand why they (LR/BMW/FORD/TATA) haven't done the same for the FFRR.
Having said the above, I've used the LR standard scissor jack to jack up my FF and remove/replace wheels and it's fine for it's basic purpose.
Only advantage of getting the LR scissor jack over the Bottle Jack is that you can stow the scissor jack with the spare wheel (well, unless you've got an LPG conversion...then your scr Censored ed any which way!!).
Hope that helps Whistle
Post #259432 14th May 2014 8:41pm
get both.....using both you can safely jack your FF up... ... - .- -.
Post #259438 14th May 2014 8:55pm
Discotigger
Good answer Stan...but that opens up a can of worms...
WHICH DO YOU USE FIRST???? Shocked Shocked
chicken and egg springs to mind Rolling with laughter Rolling with laughter
Post #259443 14th May 2014 9:21pm
iphs
Laughing Laughing Laughing
I think the bottle jack is going to be my prefered option.
Post #259447 14th May 2014 9:28pm
Discotigger
iphs, search the threads for the Merc Sprinter bottle jack (fairly recent threads on this forum).
If you're gonna get the bottle jack, that should be the best one for your needs. Thumbs Up Thumbs Up
Post #259459 14th May 2014 10:34pm
ebajema
I used the bottle jack on my flat tires and it works brilliantly, exactly what you need. They are indeed Merc Sprinter jacks and cheap and easy to get on the bay. With the adapter (BMW/Mini on the bay) it works great but even without it works (I didn't have it available for the flats).
Trolley jack of course for the stuff at home because who'd want a big trolley jack in the back of their car !! MY 2010 5.0 SC Galway green and sand interior!!
Post #259464 14th May 2014 11:27pm
iphs
Merc Sprinter bottle jack it is then. thanks chaps. Thumbs Up
Post #259478 15th May 2014 6:41am
