Home > Technical (L322) > Timing Chain Tensioner
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
My mechanic, during the last repair, told me that the car had something with the engine.
After getting the engine up to temperature, when idling, a light ffffff fffffff fffffff noise can be heard.
He told me that it is an issue with the timing chain tensioner, and that it is an engine out job.
So, questions...
Has anyone had any of these problems?
Common in tdv8's?
Is it really an engine out job?
Post #258727 11th May 2014 12:08pm
funnyguy1
United States
My 2011 SC goes in 5/21 to have a chain tensioner kit installed to quiet the irritating noise that I get every time i start up. The
dealer says it is not serious and I can keep on driving it without worrying but apparently there have been enough complaints that they have a fix for it.They said it is a 15 hour job but never mentioned the engine having to come out. Does anyone here know if it indeed has to come out for kit? If it does, I may cancel the job. I don't want the engine taken out unless it absolutely has to.
Post #258764 11th May 2014 4:56pm
Depends on the mechanic and skills.
If it isn't an engine out job, then absolutely everything at the front of the car back to the timing case comes off. EVERYTHING bar the front wings.
It's a big job, Land Rover predict 15hrs, but in real life, with a meticulous mechanic the car will be in for a week. Discovery 4 HSE
Post #258772 11th May 2014 5:23pm
funnyguy1
United States
Thanks RRUK! Now I'm having 2nd thoughts. If the dealer is saying it is more of an annoying thing than a serious issue I may just leave it as it is. What do you think?? Thx! Mike
Post #258791 11th May 2014 7:17pm
VMPP
Mine is a diesel tdv8, but being both v8's, their size is about the same.
This to say, that the engine bay, on these cars, is really cramped, and pretty much nothing can be done without dismantling most of the car surrounding the engine.
He quoted me as a 40h job, because of getting the engine out, so that he could work freely on the engine.
So it's about 1000€ to replace a 100€ part.
Post #258820 11th May 2014 9:08pm
Mike,
I got mine done and was worried about the potential for more things to go wrong after, things to leak etc following the rebuild but touch wood, it's been fine so far (It was back in early December now).
It has got rid of the diesel type chatter in the engine so it's smoother.
If you are not paying for it, then I'd say it's worth it, otherwise it's one hell of a lot of work to pay for. Discovery 4 HSE
Post #258908 12th May 2014 9:26am
funnyguy1
United States
So I have decided to get the chain tensioned kit installed on my car as it is still under warranty. I just hope they get it all back together the way they took it apart!! Will keep you updated. Mike
Post #259218 13th May 2014 3:13pm
Mike, tell them you're not in a rush and they can take their time, make sure it's done properly. Discovery 4 HSE
Post #259273 13th May 2014 9:39pm
funnyguy1
United States
I dropped my 2011 SC off at the dealer today for the warrantied chain tenisoner update kit installation. Again hearing what had to come apart to install it, grill and most of front of front of engine, an hour later I had a panic attack of that beautiful looking engine coming apart and called a few other service departments to see how many of these kits they had installed and how many owners had problems related to this. All service managers said they had done a few but never had a major problem with this, just noisy when cold. I called the dealer to have him stop the installation but they had already gotten into it and said the water pump also needed replacing so I gritted my teeth and told them to proceed. Will let everyone know how it comes out.
Post #260824 22nd May 2014 2:42am
funnyguy1
United States
DEaler called yesterday and car is finished. They had just done one a month earlier so they had it down pretty
good and it was finished in 2 days. Excited to see how it came out.
Post #261135 23rd May 2014 7:45pm
funnyguy1
United States
Picked car up and all is well. Drove the 148 miles home and it ran just fine. The clatter it use to make is gone. If you have the issue and are still under warranty, might not be a bad idea to have the dealer do the upgrade. Mike
Post #261791 28th May 2014 3:12am
Glad to hear it went ok Mike Thumbs Up Discovery 4 HSE
Post #261815 28th May 2014 9:29am
VMPP
But did they take the engine out?
Did you got to see how many hours they used for the job?
Post #262227 29th May 2014 11:38pm
funnyguy1
United States
VMPP, It took about 13 hours and the engine did not have to come out. I am sad to report though that now I have had it home
and driving it around the noise is still there. Calling dealer tomorrow and i'm not happy! Mike
Post #262237 30th May 2014 2:29am
ebajema
Wauw, that is not good. Almost sounds like they put in an original chain tensioner iso the modified one or forgot to change out the modified component(s). Or maybe didn't do the correct procedure so the initial tensioning wasn't don right (if any was needed, which I doubt).
Sorry to hear and I hope it will be sorted soon. MY 2010 5.0 SC Galway green and sand interior!!
Post #262238 30th May 2014 3:25am
