![]() | Home > Technical (L322) > Timing Chain Tensioner |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 390 ![]() ![]() |
My 2011 SC goes in 5/21 to have a chain tensioner kit installed to quiet the irritating noise that I get every time i start up. The
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Depends on the mechanic and skills.
Thanks RRUK! Now I'm having 2nd thoughts. If the dealer is saying it is more of an annoying thing than a serious issue I may just leave it as it is. What do you think?? Thx! Mike |
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 410 ![]() ![]() ![]() |
Mine is a diesel tdv8, but being both v8's, their size is about the same.
Mike, I got mine done and was worried about the potential for more things to go wrong after, things to leak etc following the rebuild but touch wood, it's been fine so far (It was back in early December now). It has got rid of the diesel type chatter in the engine so it's smoother. If you are not paying for it, then I'd say it's worth it, otherwise it's one hell of a lot of work to pay for. Discovery 4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top *Gone:L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
So I have decided to get the chain tensioned kit installed on my car as it is still under warranty. I just hope they get it all back together the way they took it apart!! Will keep you updated. Mike |
Mike, tell them you're not in a rush and they can take their time, make sure it's done properly. Discovery 4 HSE
I dropped my 2011 SC off at the dealer today for the warrantied chain tenisoner update kit installation. Again hearing what had to come apart to install it, grill and most of front of front of engine, an hour later I had a panic attack of that beautiful looking engine coming apart and called a few other service departments to see how many of these kits they had installed and how many owners had problems related to this. All service managers said they had done a few but never had a major problem with this, just noisy when cold. I called the dealer to have him stop the installation but they had already gotten into it and said the water pump also needed replacing so I gritted my teeth and told them to proceed. Will let everyone know how it comes out. |
DEaler called yesterday and car is finished. They had just done one a month earlier so they had it down pretty
Picked car up and all is well. Drove the 148 miles home and it ran just fine. The clatter it use to make is gone. If you have the issue and are still under warranty, might not be a bad idea to have the dealer do the upgrade. Mike |
Glad to hear it went ok Mike |
But did they take the engine out?
VMPP, It took about 13 hours and the engine did not have to come out. I am sad to report though that now I have had it home
Wauw, that is not good. Almost sounds like they put in an original chain tensioner iso the modified one or forgot to change out the modified component(s). Or maybe didn't do the correct procedure so the initial tensioning wasn't don right (if any was needed, which I doubt).
