![]() | Home > In Car Electronics (L322) > Fitting hybrid tv tuner HELP! |
Dr Meat Member Since: 24 Mar 2014 Location: england Posts: 23 ![]() ![]() ![]() |
Thanks i'll have a look, mine has got the manual handbrake too. |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
Checked mine last night at home. I can get a picture with no key but as soon as I turn the key to Pos II the picture goes unless the handbrake is on and the car is in Park but I still get sound on the channel I was watching. There is a difference between knowing your sh!t and knowing you're sh!t
^ yep mine the same, but I think because the light does not come on when I apply the handbrake that's why it doesn't work with the engine running. At least I know the hybrid tuner is working as it should. Now something else to fix! You never own a range rover, you just work on one! |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
I can watch TV (on the dash) in the following scenarios:-
