Home > In Car Electronics (L322) > Fitting hybrid tv tuner HELP!
Dr Meat
United Kingdom 2006 Range Rover Vogue Td6 Java Black
Thanks i'll have a look, mine has got the manual handbrake too. Thumbs Up
Post #258285 8th May 2014 4:06pm
Discotigger
The TV tuner should work with the handbrake off, it only stops the screen showing if you move the gearlever out of Park.
My TV module works when the engine is running, when in Park with the Handbrake released. My TV tuner is the AH42-19C043-AH model, it came from ebay off a 2010 RRS.
Post #258302 8th May 2014 5:56pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Checked mine last night at home. I can get a picture with no key but as soon as I turn the key to Pos II the picture goes unless the handbrake is on and the car is in Park but I still get sound on the channel I was watching. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #258376 9th May 2014 8:07am
Dr Meat
^ yep mine the same, but I think because the light does not come on when I apply the handbrake that's why it doesn't work with the engine running. At least I know the hybrid tuner is working as it should. Now something else to fix! You never own a range rover, you just work on one!
Post #258416 9th May 2014 11:52am
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
I can watch TV (on the dash) in the following scenarios:-
Engine off, press the stereo on button and everything functions as usual (not sure how long the battery would hold out though!)
Engine on in Park (it doesn't care about the handbrake status)
Engine on in Neutral + Handbrake on (red handbrake light on the dash on)
As soon as you put it into R or D I get the "For your safety....." message. I can still listen though... 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #258765 11th May 2014 3:59pm
