![]() | Home > General > Longest period your RR has been in garage for repair? |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
About 5 mins just to see if it would fit in! |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
The G4 has been in the garage (as in Workshop) pretty much since I bought it in September bar a few outings : it is being brought back to Event specs with a proper renovation after 62 000 miles. |
Re phrased |
Trev18 Member Since: 23 Apr 2013 Location: North Manchester UK Posts: 267 ![]() ![]() ![]() |
6 days the day after I picked... oil leak and the didn't have the part...
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
3 weeks+ back with the supplying dealer while I was away to try and sort a couple of problems. Still not fixed and has to go back to fix som eof the original ones and some which they caused fixing the original ones. There is a difference between knowing your sh!t and knowing you're sh!t
Keep the tales coming folks please... 3 weeks isn't good either Rej? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
6 days broken for me, though it broke on the Friday the garage didn't pick it up till the Monday, got it back on the Thursday night.
Riverstick Member Since: 06 Mar 2014 Location: Cork Posts: 117 ![]() ![]() ![]() |
Good God...What are they doing to your car for seven weeks? 2008 Range Rover TDV8 435,000kms 2015 Range Rover L405 SDV8 Autobiography 2008 Ford Focus1.6 tdci Titanium DPF deleted |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 ![]() ![]() ![]() |
Done 80K in mine...... longest stay 2.5 days for gearbox .......... Jeez are they building a new car around 4 tyres for you? 5.0 supercharged autobiography
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 ![]() ![]() ![]() |
3 months (3 X a full month) for essentially the same problem. DVD and FBH, DVD sorted, FBH is not, gave up on the FBH matter and will see an FBH specialist I think. |
3 days for alternator Present :2008 TDV8 HSE
It might be no harm to call to your local truck cab heater specialist. The FBH's are pretty simply in design & operation, but like all of these things, I am a firm believer of horses for courses....and those cab heater guys are pretty good at servicing and rectifying FBH faults. In my experience, dealer technicians are not very hot at sorting these specialist areas..... 2008 Range Rover TDV8 435,000kms 2015 Range Rover L405 SDV8 Autobiography 2008 Ford Focus1.6 tdci Titanium DPF deleted |
@Jonno, internal communication gaps? QA issues? |
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 ![]() ![]() ![]() |
Not a ff but my Mercedes CL once spent 9 months in the garage waiting for a rear wing which had corroded to be replaced under warranty.
