![]() | Home > Technical (L322) > Check coolant level! |
BigPete Member Since: 25 Apr 2014 Location: Sutton in Ashfield, Nottinghamshire Posts: 50 ![]() ![]() ![]() |
Hi all,
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
It's just a matter of waiting for the car to cool off and then checking there is enough coolant in it, just like the olden days.
OK, thanks for that. I'll get the mix checked as the fluid level is fine. hopefully its that simple........but it probably wont be. |
ah, that sounds good. where do i find such bottle? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Dan @ Duckworths? Site sponsor on here will post one |
Ask Dan from Duckworths. They are a site sponsor.
Yes, i have spoke to Dan before, very helpful fella! I'll shout him in the morning....Cheers Guys... 2011 TDV8 Autobiography |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
If there is nought wrong with your coolant tank (not saying I disagree with CTC, but I changed mine and it was fine)
Well, dealer decided to pay for this one , so new bottle and sensor fitted. Jobs a good un' |
Result !
Yes matey, no truer a word spoken |
We have found in more than 50% of cases that swapping the sensor does not fix the issue! Which means one of two things... A, the bottle comes with a different sensor? Or B, the sensor is so fragile they can be damaged during fitment... So, we only ever change the bottles now... Simples ![]() |
What I found odd was that I could change the sensor when the coolant tank was full. Does this mean that it doesn't actually sit in the coolant, but in some kind of see through bulb (glass/plastic), and perhaps it is this that gets dirty/crazed/occluded (big word for me this time of night!) and the sensor cannot "refract" the coolant? This would resolve why just changing the sensor may not work?
Witch craft Joe |
