Home > Technical (L322) > Tow Bar Rattle - Bolt Rather Than Pin?
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
I understand that there's a fix for the terrible rattle from the factory tow bar using a bolt rather than a pin - can anyone expand?
It's on a 2008 TDV8 Vogue with the height-adjustable LR drop-plate fitting.
Post #25653 16th Aug 2010 10:51pm
Vogue
instead of the quick remove pin which enables you to remove your tow bar quickly, the pin is replaced with a bolt which is helicoiled into the drawbar as well. Makes it very hard to remove, but stops the rattle.
Personally I just push a business card into the gap between the bar and mount socket to take up the slack, stops the rattle and I can remove the tow bar within 30 seconds if need be. If you want to make your tow bar thief proof, just remove the "R" clip and drill the hole out larger in the retaining pin and replace the "R" clip with a suitably sized padlock.
Post #25658 16th Aug 2010 11:23pm
Philip
Thanks - not quite so "quick-release".
Tried pieces of card, rubber sheet etc. on this and the previous one. It's never taken off, so bolting it in isn't a big deal.
Post #25683 17th Aug 2010 10:23am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
When I got mine it rattled badly and the dealer ended up fitting a new armature, mine was fitted with a North America spec one, new removable drop plate and a bolt.
I don't think my armature has a helicoil in it.
The bolt is tightened to somewhere around 160lb/ft if I remember correctly, I have got a leaaflet somewhere so will have a look for it.
It has been silent for the last five years, never been removed either.
Ian
Post #25709 17th Aug 2010 12:40pm
Philip
Will see what the dealer says when it's next serviced.
It only rattles with an empty trailer.
Post #25777 17th Aug 2010 10:44pm
nbunney
Vogue
Where is it 'helicoiled'?
I thourght the bolts were / are only for the swan neck ball.
Post #25789 18th Aug 2010 9:48am
Andy
When I bought mine, I couldn't release the towbar so I had to unbolt the mount and use the square blanking plug in it's absence. I've never been able to free it from the mount, despite emptying a whole can of WD40 into it and leaving it overnight. Anyone know of another solution? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #25797 18th Aug 2010 1:09pm
sleepezy
noddy - you could try heating the area of the plate around which the bolt is lodged into
Post #25798 18th Aug 2010 1:21pm
nbunney
Noddy
Are you talking about the swan neck type?
Where did you get your blankong plug from?
I need 2 of them
Post #25817 18th Aug 2010 5:05pm
Vogue
nbunney wrote:
Vogue
The multiheight tow bar is a socket / receiver (male /femail connector with a pin through it) almost agricultural but blooming strong - the trouble is any drawbar pitch especially on a twin axle trailer gives an annoying rattle which reverberates through the whole vehicle.
The helicoil is supposed to go into the receiver shaft which slides into the receiver, a bolt is then put through the whole lot and a nut also tightened on the other side just for good measure. I didn't have it done because I like to remove my drawbar quickly - litterally 5 seconds to remove the "R" clip and pull the pin, a nut and bolt would take 5 minutes or more - just not worth the hastle. I just slip a business card in to stop any rattle.
Post #25820 18th Aug 2010 5:16pm
Andy
nbunney wrote:
Noddy
I need 2 of them
Yes
It was in the boot when I bought the car. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #25870 19th Aug 2010 9:30am
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
I don't know if the FFRR Swan neck fitting is the same as the RRS but for RRS you have to have a key to release the tow hitch from the fitting..................... do you have the key Noddy - it is possible that it has broken off inside the lock as that was a common problem with RRS, the key was very thin and snapped easily and was very fiddly as you had to turn a plastic release at the same time as turning the key and pulling the hook out of the receiver......... a 3 handed job! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #25871 19th Aug 2010 9:45am
nbunney
Tim
Yes they do have a key, with a big red plastic handle.
Post #25951 19th Aug 2010 8:41pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Remoove bar, on 2 sides at 90deg to each other weld 2 beads per side with a mig, file to a snug fit back in the armature. spray black and apply a generouse dollop of heavy grease.
Robert is your mothers brother. letters not necessarily in the right order
Post #25970 19th Aug 2010 9:31pm
