Home > Technical (L322) > Tow Bar Rattle - Bolt Rather Than Pin? |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3720 |
instead of the quick remove pin which enables you to remove your tow bar quickly, the pin is replaced with a bolt which is helicoiled into the drawbar as well. Makes it very hard to remove, but stops the rattle.
16th Aug 2010 11:23pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2544 |
Thanks - not quite so "quick-release".
17th Aug 2010 10:23am |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
When I got mine it rattled badly and the dealer ended up fitting a new armature, mine was fitted with a North America spec one, new removable drop plate and a bolt.
17th Aug 2010 12:40pm |
Will see what the dealer says when it's next serviced.
17th Aug 2010 10:44pm |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2031 |
Vogue
18th Aug 2010 9:48am |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2934 |
When I bought mine, I couldn't release the towbar so I had to unbolt the mount and use the square blanking plug in it's absence. I've never been able to free it from the mount, despite emptying a whole can of WD40 into it and leaving it overnight. Anyone know of another solution? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
18th Aug 2010 1:09pm |
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 |
noddy - you could try heating the area of the plate around which the bolt is lodged into |
18th Aug 2010 1:21pm |
Noddy
18th Aug 2010 5:05pm |
The multiheight tow bar is a socket / receiver (male /femail connector with a pin through it) almost agricultural but blooming strong - the trouble is any drawbar pitch especially on a twin axle trailer gives an annoying rattle which reverberates through the whole vehicle. The helicoil is supposed to go into the receiver shaft which slides into the receiver, a bolt is then put through the whole lot and a nut also tightened on the other side just for good measure. I didn't have it done because I like to remove my drawbar quickly - litterally 5 seconds to remove the "R" clip and pull the pin, a nut and bolt would take 5 minutes or more - just not worth the hastle. I just slip a business card in to stop any rattle. |
18th Aug 2010 5:16pm |
Yes It was in the boot when I bought the car. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
19th Aug 2010 9:30am |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 |
I don't know if the FFRR Swan neck fitting is the same as the RRS but for RRS you have to have a key to release the tow hitch from the fitting..................... do you have the key Noddy - it is possible that it has broken off inside the lock as that was a common problem with RRS, the key was very thin and snapped easily and was very fiddly as you had to turn a plastic release at the same time as turning the key and pulling the hook out of the receiver......... a 3 handed job! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
19th Aug 2010 9:45am |
Tim
19th Aug 2010 8:41pm |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1081 |
Remoove bar, on 2 sides at 90deg to each other weld 2 beads per side with a mig, file to a snug fit back in the armature. spray black and apply a generouse dollop of heavy grease.
19th Aug 2010 9:31pm |
