Home > Maintenance & Mods (L322) > Oil leak from AT sump pan.
Hunttheshunt
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
In the last week or so I have noticed a number of oily patches on the drive under the front of the RR. The oil looks quite clear, at first I thought it was water from the AC, but it doesn't dry and stains the drive. The drive is sloped and the RR faces engine down. I have had a quick rummage under the car and the drip trays look clean and oil free and I can see no leaks around the engine. The AT sump pan though is wet and I assume that the leak is probably from the rear around the sump plug.
I need to get it booked in to get it sorted but my wife needs to use it in the meantime which is slightly concerning. Anyone had similar issues and know what the problem might be. Is it safe to drive for a few days do you think?
Regards
Paul
Post #257567 4th May 2014 10:34am
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I recently spotted oil round the front of the AT sump and feared another cracked sump, but it was engine oil seeping down from the cam covers. Will be fixing this week and will confirm.
It appears that my car has decided that 170k miles is time for everything to be replaced!!!! 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #257573 4th May 2014 10:51am
Not an easy question to answer I'm afraid... There are many many areas above there that can leak and drip down, many more in front that can leak and spray over there when the car is in motion! So, could be as simple as seepage from the drain (small problem) to a major leak up front masked by the sump protectors being thrown back to the gearbox...
Can you drive it? Well sir, thats for you to decide... I wouldn't! Thumbs Up
Post #257574 4th May 2014 10:52am
RRPhil
The sealing sleeve for the Mechatronic unit electrical connector is a very common site for fluid leaks on the 6HP26
Phil
Post #257578 4th May 2014 11:03am
Can these simply be replaced Phil? Does the fluid need draining first? Are they a LR part?
Post #257579 4th May 2014 11:06am
Hunttheshunt
Thanks chaps, I'd read about the sleeve causing problems, I'll get the garage to have a look see.
Post #257611 4th May 2014 4:16pm
RRPhil
Yes, unfortunately the fluid has to be drained and the sump pan/filter removed to provide access to the retention clip
The Land Rover part number for the sleeve (including its three seals) is TZV500010 and it costs under a tenner.
Phil
Post #257681 4th May 2014 11:10pm
hank you Phil Thumbs Up
Hopefully Stan can wiki that info Thumbs Up
Post #257685 4th May 2014 11:28pm
Hunttheshunt
Good morning,
having had the car up on the ramp it seems to be leaking from the front of the sump pan, gasket most likely. Am I correct in thinking that the pan itself is plastic of some sort? Is it a consumable item then? I assume I should replace the sleeve as well at the same time.
Thanks for your help.
Post #257990 7th May 2014 8:34am
when Craig did mine he showed me the pan and it is plastic..its crucial to tighten the bolts in the correct way and the correct torque... ... - .- -.
Post #257992 7th May 2014 8:38am
mechatronic sealing sleeve replacement 'how to' wifi'fied... Thumbs Up ... - .- -.
Post #257994 7th May 2014 8:47am
Post #257999 7th May 2014 9:19am
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
When I had my gearbox oil and sump changed I did the sleeve as part of the service - for the cost of £10 it's a no brainer....... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #258008 7th May 2014 10:25am
